09-22-2011, 03:34 AM | #1 |
Building Dreams out of Dimes!
Is anyone running a 1 ton 4x4 dually?
Hey guys I'm currently looking at a 1 ton single cab 4x4 dually.
I currently have a single cab 2wd half ton fleetside. So that is all I can compare to. Figured I would ask someone that actually has a 1 ton. How would the ride be on the 1 ton single cab 4x4 dually? Would a sb400 be enough to get it down the road and haul trailers with? Thanks! (Trying to get away from the hot rod style truck and more to a work truck.)
1981 Chevy short/wide. SB400 350th |
09-22-2011, 06:39 AM | #2 |
Next!
Re: Is anyone running a 1 ton 4x4 dually?
I have a 350 in mine and it will plow snow, haul at least 2 tons of material and it rides well for a "big" truck. all in stock condition. Buy it!
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
09-22-2011, 06:44 AM | #3 |
Thanks for the feedback! I still got to work out a few things but I'm leaning towards buying it.
09-22-2011, 07:45 AM | #4 |
How will it ride?
Like an iron-wheeled wagon. What will it pull/haul? Anything you want. They're a truck and ride like one. But they're some damned hard workin' trucks. It probably has 4.11 cogs, won't be much for highway use. What year? '87 - '88 are TBI and can run the 4L80E with a wiring harness update. If it doesn't already have 'em, add headers. They're the biggest bang for the buck, hot rod or work truck. |
09-22-2011, 08:49 AM | #5 |
The truck is an '81. I will be putting a '76 SB400 in it. (With headers!)
09-22-2011, 09:27 AM | #6 |
I have a 76 1 ton dually with a 496 I just put in it. I love the thing, rough riding ? Yes. But who cares that motor should be OK but it will be working it's ass off.
Posted via Mobile Device |
09-22-2011, 09:47 AM | #7 |
Well it looks like all the guys that do have 1 tons really love them. So would the SB400 be unempresive? My SB400 should be making around 550 lbs of torque... Is that not enough?
Are there any tricks to giving the 1 tons a better ride? I don't really need a 1 ton, I just love this truck. Different leaf springs maybe? Posted via Mobile Device
09-22-2011, 09:50 AM | #8 |
SB400 will be a hoss, swap to Vortec heads if you have the chance. Make sure you have a good radiator and water pump and it'll be fine.
I'm building a 489 for my '97 CC dually 4X4, sure looking forward to it. May end up with a turbo down the road... |
09-22-2011, 12:02 PM | #9 |
GoatLube Experss
both of mine rides decent for a 1 ton, mine are both crewcab's so I got a little more wheel base, that helps some.
if you want it to ride like a half ton, air bag it. with the right set up it will haul more wheight and ride good .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
09-22-2011, 07:50 PM | #10 |
Rough riding, bad gas mileage, pull like a son of a gun.
72 Super Cheyenne lwb 4X4 Ocra / White 88 Chevy 1 ton Dumptruck 88 Chevy 1ton Flat bed 4X4 white |
09-22-2011, 08:14 PM | #11 |
I'm doing a '97 crewcab dually 4x4, lowering it about 3", losing the bottom fat overload leaf and adding helper bags. I'm figuring it'll ride like a heavy half, pull like hell with the port injected 489!
09-22-2011, 08:29 PM | #12 |
My 1 ton is a 79, 4x4, dually, dana 60 3.73 traclok front, dana 70 3.73 powerlok rear, 454 tbi, 465, 205. I don't piss blood when finish driving it, BUT when I hook to SERIOUS loads, WE may stop moving, BUT the wheels DON'T stop SMOKING. If you're serious about not owning a "boy" truck, 1 ton speaks for it self. Ron
sorry for quality, Ron |
09-22-2011, 10:05 PM | #13 |
Next!
Cab and Chassis diesel dually 4x4s are good too!
09-22-2011, 10:44 PM | #14 | |
One more question.... Crew cab or single cab..? Big weight difference or no?
09-22-2011, 11:13 PM | #15 |
If that 400sb is putting out 500+ ft lbs of torque it would be about even with a factory big block with a mild cam so I think it would be just fine a lot of 1 ton trucks in my area have completely stock sb350s and do just fine
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-23-2011, 02:59 AM | #16 |
Sounds a lot like the 406 I'm building for my '77 K-5 with Bowtie Vortec heads. You'll have more power than most stock big block trucks, better mileage, too.
09-24-2011, 09:36 PM | #17 |
I'll probably jinx myself, but we're currently looking at a 79 K30 3+3 4x4 dually (that's a lot of alphanumerics!) with 454, 4 speed and 4.56 gears as the new tow rig.
It would just about be the perfect all around truck, except for parking at the mall. Will post pics if it works out. My only concern is the 4.56s...that's a lot of gear for the highway! |
09-24-2011, 10:44 PM | #18 |
Parking at the mall is no trouble.
Just plan on a loooong walk. |
09-25-2011, 12:57 AM | #19 |
Only thing I worry about at the mall is door dings. Kind of the reason I want a flat bed. I little harder to tear up.
1981 Chevy short/wide. SB400 350th Last edited by Hazieview; 09-25-2011 at 01:02 AM. |
09-25-2011, 01:00 AM | #20 | |
I do have the same worry about the low gears on the highway not really for fuel mileage but more so for the wear on the engine and trani from being at such s high rpm. I have an impala for fuel mileage... Posted via Mobile Device Posted via Mobile Device
09-25-2011, 01:06 AM | #21 |
Not mine, but thought I would contribute a picture.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
09-25-2011, 07:48 AM | #22 |
Next!
Military duallys M1028a2s with 205s, and they ARE mine, for now anyway.
09-25-2011, 09:48 AM | #23 |
Single cab, plain jane duallys look so tough! They're just all business
08-21-2015, 09:11 PM | #24 |
I have a 1988 chevy 4x4 1 ton duallly. 6.2 gets around pretty good.http://67-72chevytrucks.com/vboard/i...lies/chevy.gif
08-21-2015, 09:14 PM | #25 | |
There are a couple of other K30 threads on here.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
