Old 09-22-2011, 12:38 PM   #1
ChuckW
ChuckW's Avatar
Manual window regulator bushings
Has anyone had any luck replacing the nylon bushings (3ea) on the manual window regulator? (66 C10)
My regulator is in great shape other then these bushings (which aren't that bad, just a little flat spotting).
I have seen no replacement kits, parts or mods for these... Ideas or fixes welcome!!!
Thanks!!
Cww
ChuckW is offline   Reply With Quote
Old 09-22-2011, 03:22 PM   #2
brawley
Easy Does It
brawley's Avatar
Re: Manual window regulator bushings
I think classicparts. or lmc make replacement rollers for these also power window conversions.
brawley is offline   Reply With Quote
Old 09-22-2011, 03:47 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
LMC only has them for 60-63, IDK why not 64-66.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-22-2011, 05:42 PM   #4
Woogeroo
first, you have to take the whole window regulator assembly out of the door.
You have to drill/grind out the old metal parts that hold the nylon rollers on.
put in the new metal pieces with shiny new nylon rollers into the holes... make sure you have the rollers pointed the correct way... you have to 'peen' over the metal piece to make them hold... basically the metal is somewhat soft when tapped by a hammer... so it mashes down like a mushroom.
Then you put it all back together.
This is a lot easier to do if you have another set of hands helping you hold on to everything.
Someone on here took pics when they did theirs... a few years back... if I can recall who, I'll post the link.
-W
Woogeroo is offline   Reply With Quote
