09-22-2011, 01:28 PM | #1 |
air line size
what size air line do ya recommend i got the ss7
09-22-2011, 01:39 PM | #2 |
67-72 parts collector,…
Re: air line size
3/8" max.
1/2" is too fast.
09-22-2011, 06:50 PM | #3 |
Re: air line size
I ran 1/2" on the tank side of the valve block and 3/8" from the valve block to the bags.
09-22-2011, 07:46 PM | #4 |
Re: air line size
aight cool. thanx
09-25-2011, 10:15 PM | #5 |
Re: air line size
does anyone run 3/8 for the front and 1/4 for the rear since theres less weight in the rear, so the lift speed would match?
09-26-2011, 05:24 PM | #6 |
needs more $$$
Re: air line size
I'm running 1/2" all around. However, my tank only has 3/8" outlets. I was scared about them being too fast, so I plumbed in flow controls. I don't know if just the 3/8" out of the tank is slowing it down or the flow controls are because with the controls wide open it's perfect in my book...Fast enough to look "cool", but still slow enough so I can control the height with ease.
1970 2wd Blazer |
09-26-2011, 10:15 PM | #7 |
Re: air line size
I had to slow the front down a bunch running half in all the way. Ended up using a plug and drilling a 3/16" hole in the center of it on the dump valve.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
09-27-2011, 03:57 PM | #8 |
Re: air line size
I ran all 1/2" in my '69 and there was no stopping it from all up to all down. I installed dump and fill adjusters and was able to dial it in well.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
