www.67HEAVEN.com
Is a 1989 crew cab grill a bolt in?
Will a 1989 crew cab Chevy grill bolt into any 1981-87 C10-C30, assuming you also change the matching headlight bezels?
Thanks.
www.67HEAVEN.com 2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme) 1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme) 1967 Belair 2-door-post (project) 1967 Corvette 427/435 coupe (now 502/502 red road warrior)
Re: Is a 1989 crew cab grill a bolt in?
you'd also have to have the radiator support
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
Slots go on anything!
headlamps, parklamps, wiring pigtail, and lower grille filler are different as well.
1974 Jimmy- 5.3/4L80e/NP241 |
www.67HEAVEN.com
Wow, I hadn't thought of that. I probably don't have to remind you guys, but the crew cabs were a carry-over body style in 1988-91. Same body as the 1987 and older.
Would a 1981-1987 C10 really need a different rad support to use the crew cab grill from 1989? In other words, did the 1988-91 crew cab have a different rad support from all the other years? ![]() Here's a look at one.
yes, because of the horizontal mounting of the headlights.
Getting Old; Going Broke
One more telling you that you have to swap the radiator support and lower grille/bumper filler and lamp harness, then add the lamps and grille and bezels.
The first clue is the lamps going horizontal from each other instead of vertical. They have to sit in their buckets and those buckets have to sit in their indentations in the core support.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
If you're able to get the whole front end, then the swap is pretty cut and dry because you'll have everything you need, you just have to splice your original headlight harness. If your only getting the grille and bezels, then you're gonna have to track down everything else.
![]() Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
www.67HEAVEN.com
Thanks for the information, everyone. It's good to know what to expect ahead of time.
Cheers.
![]() Join Date: May 2009
That is also the same as the K5 Blazer and Suburban nose.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
Happy to be here
![]() Join Date: Mar 2000
Yes it is. If you like that look, find an 88-91 Burb and grab the whole front clip.
| Bookmarks |
