09-22-2011, 06:50 PM | #1 |
Resident of Here
Best Budget Mods!
Well the 67-72 guys have one! We need one!
http://67-72chevytrucks.com/vboard/s...d.php?t=466563 The rules are in that thread. Post away!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
09-23-2011, 01:43 AM | #2 |
Another Day, Another Dollar
Re: Best Budget Mods!
If you have a 2" hitch receiver lightly sand and paint the sucker.
It won't even take a whole can and it makes a world of difference. I do mine every couple of years. ps. awsome thread!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
09-23-2011, 01:55 AM | #3 |
New leaf spring bushings make a world of difference in the ride.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
09-23-2011, 02:49 AM | #4 |
Best thing I have spent $50 on has gotta be a tank of gas....Maybe technically not a ''mod'' but what good is a square without it??
09-23-2011, 07:23 AM | #5 |
78K & 79C Jimmys
over the years ive had quite a few GMs and done this in other trucks /vans too
in my Jimmy thread i showed how i wire the stock radio to be used with/without the keys small switch beside the radio,up on, no key,middle off,down works with key (kids,drunk friends,camping don't need to leave the keys in to listen to the radio)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-23-2011, 12:22 PM | #6 |
Flip the air cleaner lid over and make your quadrajet go waaaaaaaaaaaaaa!
The cheap mod I'm happiest with is the $3 I spent at the boneyard to put a newer windshield washer pump in. It now literally power washes dirt off the windshield. |
09-23-2011, 01:16 PM | #7 |
^^^ nice!
66 GMC Suburban Custom 66 Chevy K10 Suburban |
09-23-2011, 02:39 PM | #8 |
GoatLube Experss
this is on one of my S10's, but it will work on any vehicle.
I gut'd the steer'n colum but the skinny shaft look'd funny with the big notch in the dash. so I took a piece of 3" PVC , cut it to length then stuck an adaptor over that , I drill'd and tap'd 3 hole's around each end and found the perfect lenght screw's so when I tight'nd em up it hold's tight to the colum the 3" is perfect for dash and the adaptor fit's the bottom of the wheel perectly also. clean'd it all up and paint'd it black, look's clean with accessories hang'n off of it. I had every thing lay'n around so it did'nt cost any thing ! this is only picture I have with me, but you get the idea.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
09-23-2011, 03:09 PM | #9 |
I have will break mine into multiple parts that all cost about 50 bucks and could be done in a weekend. Here is what I started with, the 85 k1500. 25 years of direct Arizona sun gave it the nice patina and a tweeker with a tire iron worked over the front end. I got tired of driving it looking this bad.
First 50 dollar mod was the rattle can primer job, 10 cans of paint and some cheap sanding blocks and sand paper from harbor freight, masking tape and a sore index finger will yield this awesome look. Next mod to make the front end look better is roughly around 50 bucks, depending on what you need to replace it could be under or over 50 bucks. In my case I needed: Trim pieces from the parts yard- about 10 bucks. Reproduction grill- 20 from rockauto. Headlight bezels- 12 bucks a piece from LMC. turn signal lenses- few bucks a piece from the parts yard. |
09-23-2011, 03:16 PM | #10 |
One of my favorite 50 dollar mods:
Tail light lenses I found at Orileys for 17.99 a piece. You can find these alot cheaper, I went with these because they were made in the USA! The last few bucks left can go to a can of silver spray paint to make the inner tail light parts a little more reflective. End result looks way better than the old faded lenses, the big bonus is added safety since they are alot more visable. |
09-24-2011, 12:01 AM | #11 |
Resident of Here
Nice job irishman!
09-24-2011, 12:11 AM | #12 |
Square
Squarebody Syndicate |
09-24-2011, 01:57 AM | #13 |
False advertisement. I want a rebursement on my clicks. This thread contains no usefull info.
Posted via Mobile Device |
09-24-2011, 02:05 AM | #14 |
09-24-2011, 04:04 AM | #15 |
strip led's in the dash and k&n filter, both under 50 dollars, synthetic oil is nice too hmm about 20 hours and some polish makes rims like A/R's and mags look good to. also buy a buffing wheel and compound and mount the wheel to a bench grinder and polish your trim on the grill and surround,
and my most favorite mod is....metalic sharpie....go to town on your interior guys really!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-24-2011, 10:17 AM | #16 |
Catchy title goes here..
09-24-2011, 10:37 AM | #17 |
Resident of Here
09-24-2011, 10:50 AM | #18 |
A bunch of the budget mods in the 67-72 thread also apply to ours. (I haven't read the whole thread, but will later)
HEI conversion if your still on points ignition. Manual of some sort, (Chiltons, Haynes, GM... not really a mod, but very help-full) Simple maintenance items. Plugs, wires, brake shoes, fluids+filters. Once everything is tip-top, verify timing advance. (check the sticky!) You don't need a fancy dial-back light. Timing tape on the balancer and patience. These old Chevy's really wake up with a little timing.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
09-24-2011, 05:45 PM | #19 |
I had a worn out shifter assembly for a 203 transfer case. Nothing was available to replace it. So a little reworking was needed.
3/8 flat bar for the second lever. All welded up. Exploded view. And finished. About 3 hours work, and about 4bucks. All he needs to do is get a new shift boot.
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
09-24-2011, 09:21 PM | #20 |
Thats a pretty cool fix VegasBruce!!
09-24-2011, 09:29 PM | #21 |
09-27-2011, 11:37 PM | #22 |
Does your truck have a buzzer/chime if you leave your lights on? Mine doesn't and i'm hoping it is because it is a Custom Deluxe.
If not, is there a cheap/easy way to add one? You can probably guess what happened to me at work today; It was raining, i was in a hurry............etc. etc. etc. |
09-28-2011, 12:01 AM | #23 | |
78K & 79C Jimmys
09-28-2011, 11:53 AM | #24 |
Yes, but how?
09-28-2011, 08:06 PM | #25 | |
Salty Sailor
i have done this a few times. i would also like to do this mod. anybody done it before?
86 c-10 Custom Deluxe Savannah, Georgia |
