04-12-2003, 07:11 PM | #1 |
steering column movement
I just put a different steering wheel on and I've noticed when I pull the wheel towards me, I have about 3/8 to 1/2 inch movement. I never paid any attention to this before because I've never pulled on the wheel. Is this normal? Is there a way to stop this(other than don't do it)?
04-12-2003, 07:25 PM | #2 |
i love summertime
there should be a bracket that has a couple bolts to the firewall and it is shaped to the contour of your columb, with a clamp going around it, that is all i can think of....
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
04-12-2003, 07:32 PM | #3 |
go bucks!
also, double check the rag joint down at the steering gear.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
04-12-2003, 07:34 PM | #4 |
Rag joint will cause about that much give when the steering wheel's not torqued down. I suggest removing the horn cap and tightening down the steering wheel nut. Shouldn't have much give after that.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
04-12-2003, 07:45 PM | #5 |
I machined about that much of the back of the wheel so I could I could use my old horn ring. Should that matter or should I try to shim it to pull the play out? The new wheel had a tapered collar that was removed to flatten it out.
