09-22-2011, 08:04 PM | #1 |
Rear axle woes :(
The posi Dana 60 in my 71 C20 has pretty much bit the dust. The housing is messed up due to play in the gears. Took it to a shop and they said it is beyond economical repair. The problem I have been having is I cannot find another Dana 60 anywhere.
So I figure now is a time to look at some other options. I would love to have an axle that is posi or locking diff and perhaps rear discs. Anyone have any insight as to other economical options for a rear axle for my truck? Would an axle out of a newer GMC fit without too many problems? |
09-22-2011, 09:19 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Rear axle woes :(
I have heard 14 bolts are the way to go. maybe someone with actual knowledge will chime in and assist ya.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-27-2011, 10:32 AM | #3 |
Thanks Clyde, I have also heard about the 14 bolt axles being a dime a dozen and good axles. I'm going to be on the hunt this week for an axle. Any other options or is the 14 bolt the best route?
09-27-2011, 01:26 PM | #4 |
~Rest In Peace~
i would check with junkyards for old rv's alot of these rv had dana 60 rear ends ,just sayin
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-27-2011, 04:05 PM | #5 |
Depending on what gear ratio you want, My choice is the eaton, with a detroit locker.
09-27-2011, 08:08 PM | #6 |
I think I will stick with the stock 4:10 gear ratio
Posted via Mobile Device |
09-28-2011, 06:20 AM | #7 |
Is your truck leaf spring? 14-bolts only require the shock mounts and spring pads relocated. Is you posi wiped or just the ring & pinion due to worn carrier and pinion bearings?
10-05-2011, 09:26 PM | #8 |
Been pretty busy, haven't kept up with the thread and still haven't found an axle yet.
Specialk, yes, my truck is leaf spring and the "banjo housing" has wear. My guess is the previous owner did some work on the gears and messed something up, the housing has abnormal wear and is now pretty much useless. I am kind of leaning towards an axle out of a 2000 and up 3/4 ton truck, especially if I have to relocate spring pads and shock mounts anyways. Disc brakes and a locking diff sound pretty good to me. Has anyone done this swap? |
10-05-2011, 09:56 PM | #9 | |
Vintage 4x4s
Also, heard a rumor that kits may become available for converting Eaton's to discs.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
10-05-2011, 11:16 PM | #10 |
If you have measurements from your 01, Vintage Windmills, that would for sure be helpful. I believe the D60 is 65 inches between where the wheels mount. What is a reasonable price to pay for a newer axle with locker/discs?
71 GMC C2500 350 all original, 80k miles, work truck 71 Chev C20 350 currently needs rear axle, play truck Both baby blue from the factory |
10-07-2011, 01:23 AM | #11 |
It's not a newer axle, but here is a D60 in Minneapolis for a price compare:
http://minneapolis.craigslist.org/ra...595894113.html was looking on Craig's today and saw this ad. it is actually the rear from my parts truck I sold about a month ago....guess the guy I sold it to has been busy. if I had time i would have torn the truck down...kinda regretting it right now... anyway, D60's are out there...just keep lookin. Good luck!
1971 C-20 350/350 |
10-07-2011, 04:01 AM | #12 |
If you feel like a drive down the coast.. there's a few in the local Craigslist.. one's been on there forever..
http://losangeles.craigslist.org/wst...604260306.html http://ventura.craigslist.org/pts/2602856043.html
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
10-07-2011, 01:05 PM | #13 |
Hey I've got a dana 60 out of a 71 gmc c-20 you can have just come pick it up. I'm up in Quesnel it's yours if you want it
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
10-07-2011, 02:23 PM | #14 |
Rollinhard! You just made my day, I'll send you a message after work!
10-07-2011, 05:28 PM | #15 |
No problem. I will go look at it tomorrow and confirm weather it is a posi and what gear ratio it is
