![]() Join Date: Nov 2007
63 Chevy SWB 4 X 4 off the mountain
Drugged this down the mountain the other night. Someone put a 366 big block in it. Not too bad a start for a new project. Would like to put a 327 back in it.
Tim |
Re: 63 Chevy SWB 4 X 4 off the mountain
Great truck. Love the 4x4's. You don't see them everyday.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Nice, really nice truck to start with. A driver? Have you seen literature on the truck?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Wow. I'm not a big fan of those knee knocker cabs but that thing is bad ass. Congrats.
Posted via Mobile Device Do my eyes deceive me or are those 62 badges on a 63? |
3/4 t axles? I dig it! Is it a runner?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
That looks like the truck from Eureka Springs. How far are you from Springdale?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Looks like a decent solid truck....nice score. Did they hack things up to install the big block?
I have to say, looking at the firewall and steering column and badges on the cowl corners, I would say it is a '62 with a '63 grill. Of course who knows what all has been changed over the years.
I like it . you can have some real fun with a truck like that .
#12 | |
I was lucky they built a cross member motormount and just bolted it in. Did not cut the frame, they custom built the exhaust manifolds out of pipe, cleared the frame. Is there a way to tell the difference of a 62 or 63 cab, do they mount different on the frame? Thanks, Tim |
#13 |
1966 Crew Cab & 4X4 Fanatic
I like it when one 4x4 is not enough.
#14 |
#15 |
G
#16 |
wish i could find 4x4s like that around here where i live.i have to build them.thats looks to be a nice truck.have fun!
triple d |
#17 | |
60-66 Nut
A couple of easy ways to ID a '60-'62 cab from the '63-'66's is the front cab mounts on the '60-'62's are farther from the frame than the '63-'66's. The front bolts on the '63-'66's are only about 3" out from the frame. One other way is the provisions for the combination brake master and clutch master on the firewall. The '63-'66's did not have a hydraulic clutch. Another way is the '60-'62's had the cable operated vents in the kick panels with the louvers. One thing I saw in one of your pics above is the steering column shaft just forward of the firewall support. The '60-'62's have that kind of universal joint there whereas the '63-'66's do not. They have just one solid shaft from the steering wheel to the rag joint.
