Old 09-22-2011, 09:14 PM   #1
Sixxer
Sixxer's Avatar
C20 Tubular Control Arm Install Problem
Need some help from you guys... I am in the process of installing a set of tubular control arms for a c10. The problem is the lower control arm shaft mounts as a plate and the new shafts mount using U-bolts. Does anyone have measurements or know which hole to utilize and which one needs re-drilled to mount these?
Sixxer is offline   Reply With Quote
