Old 09-23-2011, 12:42 PM   #1
mknittle
mknittle's Avatar
Is there any diffrance between 1/2 and 3/4 ton trailing arms?
I usually hang out on the 47-59 side of this board. what I am tryng to find out is if lat 60s 1/2 and 3/4 ton rear trailing arm interchange. they look like they are the same aside from a plate under the spring.
thanks Mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-23-2011, 12:50 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Is there any diffrance between 1/2 and 3/4 ton trailing arms?
Just the plates they interchange
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 09-23-2011, 01:16 PM   #3
mknittle
mknittle's Avatar
Thanks, that's what I thought. that makes life easier I have a 1/2t with a body if you can call it that. and a 3/4t with no body and I need the X member as well as the trailing arms.
Mark
Mark
My GMC build.
