Old 09-23-2011, 06:46 PM   #1
86Burban
86Burban's Avatar
Vibration after Diff Fluid Change - Pls Help
Need some help please!
-86 Suburban k1500, 4x4
-Changed front and rear diff fluid - synthetic
-Filled to just seeping from fill plug...let sit till done dripping out then secured plugs
-drove and now have vibration...can't tell if from front/back as it is in both steering wheel and seat
Did I overfill? If so what distance below the fill plug holes should it be?
Thanks, e
86Burban is offline   Reply With Quote
Old 09-27-2011, 12:55 PM   #2
86Burban
86Burban's Avatar
Re: Vibration after Diff Fluid Change - Pls Help
Anyone?
Old 09-27-2011, 06:59 PM   #3
Dieselburb86
Sounds like a drive shaft to me! I drive a 1986 GMC suburban and the rear drive shaft has a nice size dent in it towards the dif, and its causing the same type of vibration.
Dieselburb86 is offline   Reply With Quote
Old 09-29-2011, 09:32 AM   #4
Smier
I've always filled mine till it comes out the plug. Is it "whining" at all? Was the truck sitting level when you filled it? Pull the plug and stick your finger in, is it low? I did the same thing once and after driving a few miles I had a vibration and "whine" from the rear differential. I pulled the plug and I was low on fluid. I guess I didn't allow enough time for it to ooze everywhere it needed to. Topped her off and I was good to go. Other than that, check the ujoints for sure.
Smier is offline   Reply With Quote
Old 09-29-2011, 09:43 AM   #5
86Burban
86Burban's Avatar
Thanks...no whining that I can hear. The vibration has quited slightly but still there. I will re-check the fluid level (but did find in the owners manual where it did specifically state to fill to the drain plug level).
