09-23-2011, 09:25 PM | #1 |
Which SBC Starter
I am looking for a starter for my 350 Chevy. I have looked in the archive and have received an education. I have a 168 tooth flexplate on my engine. All of the archive info shows that a 168 tooth flexplate uses a staggered bolt pattern starter. Looking at the photos of starters on the site as well as ebay, the staggered starter pattern has the outer bolt hole toward the rear of the vehicle as compared to the inner bolt hole which is closer to the front of the vehicle. My engine has the outer hole toward the front as compared to the inner which is to the rear. Please take a look at the pictures.
09-23-2011, 09:30 PM | #2 |
Re: Which SBC Starter
They're all on the passenger side, you'll be OK.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-23-2011, 09:43 PM | #3 |
I know it sounds crazy but I can't get my brain around this. I have been under, and back and forth from the truck to the computer a hundred times.
09-24-2011, 08:45 AM | #4 |
Just a car guy
Your motor is correct, nothing to worry about.
If you want to stick with a parts store starter, I would get one for a 1996 Chevy truck, 350. It will bolt up, but is much smaller than the stock ones.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
09-24-2011, 09:25 AM | #5 |
So,, what else you got???
OJ is right. We run the 96 Chevy starters on all our Chevy trucks. Smaller, lighter, header clearance and really turn the engine.
09-24-2011, 01:15 PM | #6 |
to avoid any headaches just ask for a starter on a 98 chevy tahoe at the parts store, 95-97 were crossover years and depending on the person behind the counter they could still hand you an old school bulky starter versus a later model gear reduction starter. you're also going to need some new starter bolts since the old style bolts are too long
09-24-2011, 01:32 PM | #7 | |
09-24-2011, 01:40 PM | #8 |
Just a car guy
I don't know how much gear reduction it has, but they sound like one.
They look more like a plain mini starter. http://www.autozone.com/autozone/par...29152_55002_0_ I am actually running a Jegs gear reduction starter on my truck as well as the bbc in my 55.
09-24-2011, 01:41 PM | #9 |
Just a car guy
09-24-2011, 01:47 PM | #10 |
thanks for the info.....
09-24-2011, 04:03 PM | #11 | |
I am running a high torque old style ....which is heavy ...but my main problem is hot start from the header heat soak situation, cold start is fine. 10:1 355 w/forged flat tops ....maybe I'll try another heat shield last one was a piece of junk. another wondering thread ....... |
09-24-2011, 04:10 PM | #12 |
Just a car guy
I ran the factory type on my 3rd gen camaro, with headers, 10:1 compression. Never had any issues.
I have the jegs one on our 55, with an 11:1 427 big block, and headers, no issues with it either. I have the jegs on on my truck too, but its a stock 350.
09-24-2011, 04:19 PM | #13 |
Thanks Guys, I was away from the computer for the last 12 hours or so and you guys really ran with it. Thanks again.
09-24-2011, 04:22 PM | #14 |
sending pm....Rush
