09-23-2011, 10:41 PM | #1 |
Running Billet Spacers??
Anybody running billet spacers with their 20" rims or other size wheels? Will 1.25" spacers work with 20x8.5" wheels? I picked up a set of Boss 20x8.5" wheels with a 14 offset. I'm looking to fill the fender wells a little more. Let me know and let's see some pics of what wheels ur running and how it looks with the spacers. Thanks in advance.
Posted via Mobile Device |
09-24-2011, 02:22 PM | #2 |
Re: Running Billet Spacers??
Anybody??? Pics are not neccessary but I'm curious because I don't want to buy them if they're not recommended.
09-24-2011, 07:24 PM | #3 |
I had 1.25" Spacers with 15" rally's, it helped alot bring the wheels out. Be careful when buying spacers, some are inferior to others.
Honestly, I would have some made. www.motorsport-tech.com |
09-24-2011, 07:33 PM | #4 |
running billet 1.25" spacers on the back of my burb with 20x8.5"s and no problems here, was running 1.5" spacers but wanted the extra room when riding low and laid out, so thats why i went to thinner ones
09-24-2011, 08:38 PM | #5 |
Newbee
I run billet spacers on the back of my ferd 4x4 for a little more articulation clearance with 36's. I beat on them pretty good! No issues yet with a heavy wheel and tire combo.
Check torque often for awhile though. They can loosen up. |
09-24-2011, 08:54 PM | #6 | |
09-24-2011, 11:04 PM | #7 | |
Heres a link to some pictures. http://67-72chevytrucks.com/vboard/s...d.php?t=412616 |
09-25-2011, 02:05 AM | #8 | |
By the way muthstryker..... your square is as good lookin as they come. Thanks for the link. Love those wheels. I wish I could afford a set!! Posted via Mobile Device |
09-25-2011, 02:43 AM | #9 |
I run 1.5 inch on each side on the front of my dually ....they come from the factory with the wheels sucked way in on the front. The extra 3 inches of track width gets the offset where it looks "right" when looking down the side.
09-25-2011, 10:41 AM | #10 | |
What size wheel/tire combo you plan to run, what ride height your truck has, & what 'look' you prefer all need to be considered when determining if billet adapters are necessary.
09-25-2011, 11:14 AM | #11 | |
09-25-2011, 11:16 AM | #12 |
I have them on my blazer in the rear with my boss 338s. I had them in the front too until I machined the hub down to fit.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
09-25-2011, 12:10 PM | #13 | |
What size wheels/tires?
09-25-2011, 03:05 PM | #14 | |
A 1.25" - 1.5" spacer on the back of your truck would be perfect. I would stay away from adding one to the front, yes the guy with the dually did it but his rear tires are all ready wide enough. If you add a spacer to the front and the rear, it will look funny still because the rear will still be in further then the front. Best way to measure for which size spacer is so put the wheel on the truck, and then just measure from the face of the wheel to about where you want the wheel to sit. |
09-25-2011, 03:23 PM | #15 |
Oh and like I said I would look at having the spacers made by the guys I posted a link to above, The spacers can be made Hub AND Wheel centric which is important to keep the wheel from vibrating.
09-25-2011, 04:35 PM | #16 |
09-25-2011, 09:35 PM | #17 |
I wouldnt stagger your tire heights like that.. Thats a 3" difference front to rear and honestly, wouldnt look that good at all. Unless that rear wheel was like 10"+ wide its going to look off..
I would run a 255/40/20 all around. |
09-25-2011, 10:20 PM | #18 | |
