![]() Join Date: Sep 2002
Hood latch question
Recently picked up a 68 and have a problem releasing the hood. When I looked at the latch assembly I noticed that the bar that you push up to release the hood hits against the upper grille preventing it from moving up far enough to fully release the hood.
I removed the assembly and was gonna replace it with one I took off a 69 but noticed that were the same. Is the 68 hood release assembly different than 69 and up? Any info would be appreciated. Thanks! |
I am a Referee of life.
I had this problem on a 67 and I removed the latch assembly(which you already did) then I chucked it up in a vise and bent the handle so it would clear.I think I used a cresent wrench to give me enough leverage to bend it.Then I reinstalled it and it worked great.Lube it while it's out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
So Many Ideas, So Little Money
69-72 latches are differnt yes
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
