Carpe manana
![]() ![]() Join Date: Dec 2010
Need help: Suspect bum NOS ebay purchase
This was billed as a NOS cargo lamp/lens/gasket from an ebay seller. The lamp assembly has surface rust that would conform to the rubber grommets that attach it to the cab and some white corrosion on one of the electrical connectors. Also, the rubber gasket lacks a GM part number. Anyone seen a NOS assembly in like condition or a NOS gasket that lacks a part number? I haven't.
Thanks for looking.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Need help: Suspect bum NOS ebay purchase
Rust on the screw holes to me is a telltale sign its been mounted.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Carpe manana
Me too. I think it's a used part but am in disagreement with the seller. As far as I know the assembly gaskets had part numbers.
Looks like you got burned, unfortunately there are people today that think, everything that looks old is "NOS".
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Definately not NOS. Been mounted for sure.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Looks mounted. Sorry man can't trust ebayers
1969 Chevy c20(Miss Hackjob) |
fat old dude
![]() Join Date: Feb 2010
that looks mounted.
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
Someone posted a close up of that same gasket a week or so ago and it had a part number. That housing has definitely been mounted, I.E. not NOS.
VA72C10
![]() Join Date: Mar 2008
![]() and on the gasket I haven't seen an original or NOS without the part number so that looks aftermarket...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
its all about the +6 inches
what did you pay?
i'd contact the seller and start off asking what he/she thinks NOS even means. |
Definitely an outright misrepresentation. It's "used" and the gasket is reproduction. Asking a dishonest person any questions will no doubt bring a dishonest answer. Report the S.O.B.,give negative feedback,or whatever. It doesn't matter what you paid,it's an auction and the seller doesn't determine the price. Their job is to give honest info.
Who was it? Post a thread in Bad Deals so others can check there before bidding.
Was there pics online of it ?
#13 |
Carpe manana
The online pics were not detailed enough to see the flaws/lack of part number. If they were I wouldn't have purchased the item. I've purchased many NOS and used parts from ebay and all were accurately described. I haven't had a problem previously.
Thanks to all your your input. I appreciate it.
#14 |
Sucks, tell eBay an get your money back.
#15 |
if you used pay pal tell them there pretty good on that kind of stuff
big old burb in primer.lot of work to do. |
#16 |
What has the seller said? If he didn't know he may just return it and you'll be out the shipping... Fair enough to me, the pictures should of shown the rust marks...
#17 | ||
"I ain't nobody, dork."
The seller probably doesn't even know the true meaning of the term NOS (New Old Stock). To them it probably means any old part. NOS stuff "should" come in the factory packaging too. Unless noted by the seller.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#18 |
Still Learning
File a protest with Ebay first. They will hold the return payment until you return it with a tracking number. Once it's returned to the seller, you will get a full refund including the initial shipping charge. Ebay will side in your favor for sure.
Sorry for the bad deal. There are a few out there that try to scam and deceive. |
#19 | |
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#20 |
fat old dude
the light i removed had numbers on the gasket.
#21 |
Carpe manana
After some back and forth the seller has agreed to a full refund. The lamp is on its way back as of today. Lesson learned.
Here's some of our correspondence that suggests he knows what a NOS part is as distinct from a used part: Me: I received my items today. The gasket lacks a GM part # and is therefore an aftermarket piece not NOS as you advertised. Also, the lens assembly showed evidence of being used like rust where the mounting bolts attach to the rubber grommets on the cab. Please refund my money and I will send this back to you. The parts are not as described. Seller: ...thanks for the email. I am sorry you are not happy with the part. It is NOS just as described in the auction. Not all parts have the GM number stamped into them and the base has never been mounted. You may have wanted a perfect part and this was not but it is New Old Stock. Did you email before you bid with any condition concerns? If you did and I mislead you please send me a copy of that email and I will make it right. If not feel free to send the part back and I will sell it to the second place bidder you will only be responsible for shipping both ways, thanks...
