Old 09-25-2011, 12:12 AM   #1
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Gear install - DIY or Shop
I bought new gears for my front D60. I have never installed a set of gears before. Should I give it a shot or just take it to a shop to have installed? I'd like to give it a try, but I'm worried about jacking crap up. Thanks in advance for the input.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-25-2011, 05:46 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Gear install - DIY or Shop
I was going to do my own on a CC Dually 4x4 conversion that I had built. The front was 4:11 and the rear was 3:73. After a little research, I brought it to Rearend Specialties in San Jose and they knocked it out in 3 hours. There was no way I could have done it faster or cheaper by the time I had bought the tools to do it, let alone possibly setting it up wrong and smoking a new gearset. I've heard that once you've done a few of them, they are fairly easy but I couldn't afford the education. I'd check with a local shop that does alot of them. They'll know all the shortcuts
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-25-2011, 05:48 PM   #3
msgross
msgross's Avatar
I agree... depends how much wheeling you do...
I would never do the rear but might attempt the front.. I don't use the 4WD much so getting it "close enough" would probably work for me. But the rear is used 100% of the time so I want a pro... I bet a shop will do it for $100-$150...if you have the parts
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-25-2011, 06:16 PM   #4
LONGHAIR
Definitely not a DIY. Find a good local shop. You get a warranty and miss out on the headaches.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-26-2011, 09:44 AM   #5
Burt4x4
Burt4x4's Avatar
Ya I would take it in unless you really want to learn and trust you can do it right. I did it ONCE..both front and rear in my driveway/garage and it took me 4 weeks and 4 cases of beer to get the job done
Lots of research on the internet..checking and double checking...tearing it down..put it back..tearing it out agin..put it back...
It was an experiance but now a days I pay to have gears put in...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-26-2011, 10:14 AM   #6
rayfinseats
All you basically have to worry about is backlash and gear contact. You'll need a dial gauge and that yellow paint stuff that comes in the install kits. You'll probably need a press for the pinion gear. If it uses a spacer instead of a crush sleeve on the pinion just get a new bearing and hone it out till it slips on the pinion by hand. Once you get it shimmed right, you can press on the new bearing.
rayfinseats is offline   Reply With Quote
Old 09-26-2011, 11:26 AM   #7
snj8198
snj8198's Avatar
I am merely a shade tree and trail side mechanic with enough tools to get myself into trouble and (if lucky) get half way out. I have done my own R&P installs on a 10 bolt front, 12 bolts, D44, and 14 bolts. "IF" a guy has his choice, start with the ff14 bolt for an easier first time experience. I am pleasantly surprised with my installs, and the gears' longevity are leaving me with some confidence building results. The last time I paid a shop to set R&P was 10 years ago. A front swap cost me $500 in labor, the rear $400, I had all parts in hand. I vowed to never do that again. After watching a hand full of live installs, and plenty of videos, I started doing them myself.
If I knew this was an occasional experience I would take mine in to a shop. If a guy plans to monkey around with offroad rigs and tire size changes that necessitate gear swaps then now is the time to learn. It will save you labor money that you can use to buy tools with! But if this is to be an occasional experience, I would take it in and save the potential headaches.
Sorry for getting all excited,
-steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-26-2011, 08:52 PM   #8
LONGHAIR
Around here that is too much money. It really shouldn't cost much more than half that...
Old 09-26-2011, 09:25 PM   #9
snj8198
snj8198's Avatar
Ya it sure was, I know better now. Young and dumb then. Now, just dumb.
Steve
Old 09-26-2011, 11:46 PM   #10
ryanroo
ryanroo's Avatar
r&p is a pretty easy set up. 14 bolts are the easiest thing to learn on, but danas are not that bad. some kits come with a crush sleeve you can use on 60s, but it is definately better to use the shim set up. as said a set up bearing can be used on the pinion and carrier to make lif a little easier. alot of gear sets will have a number engraved on the pinion that gives you a decent starting point for depth, but if not the shim pack that came out of it is always a good place to start. backlash and depth, get both in tolerance and you should be good. if time is not a concern i say do it yourself. its not that hard, and its a good thing to know
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-27-2011, 12:39 AM   #11
67_SS396
If you have the tools, patience and able to research, it's not hard. The 14FF has to be the easiest to set up, then the 60 with a close second.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-27-2011, 08:24 PM   #12
LONGHAIR
Yeah, that's all
Uh, no.....It's very easy for a beginner to screw-up.
It is just not an easy project. There are lots of steps involved and it must be done perfectly. "Good enough" is not good enough
Old 09-27-2011, 10:11 PM   #13
ryanroo
ryanroo's Avatar
Originally Posted by LONGHAIR View Post
Yeah, that's all
its easy for a beginner to mess up valve cover gaskets too. its still easy if you understand the process. there are lots of steps to build an erector set bridge. just because someone is a beginner does not mean that they are not able to set up gears in a an acceptable manner. i was a beginner the first time i did it. still came out fine.
ryan
72 K20 12v build
Old 09-30-2011, 08:32 AM   #14
Chevy1TonFun
Grease Monkey
Well I called around. Its $600 everywhere I called. I'll be giving myself an education on how to setup a r&p.
Old 09-30-2011, 11:31 AM   #15
LONGHAIR
ryan
If it was easy, it would be cheap.....It's not, so it's not.
I have absolutely no interest in debating you, but I feel that it is my responsibility to share my experience. I did this for many years, with all of the proper tools and training, many times with extremely low gears and they are far more touchy. More than a few were replacements for people who tried it for themselves.
I'm not saying that it can't be done by printed (or video) material, but a guy had better be very well prepared....and it's just not worth the effort and expense required when you can hire it done and get a warranty too.
I was a beginner the first time too, but I did have an experienced Pro helping.
BTW, valve cover gasket failure is far less catastrophic
Old 09-30-2011, 12:30 PM   #16
Redcap
Call more places. It is $200 flat up here.
Redcap is offline   Reply With Quote
Old 09-30-2011, 12:52 PM   #17
parrisc19844x4_468
parrisc19844x4_468's Avatar
I just checked with my neighbor who has his own shop, mostly works on pulling tractors and trucks, he is saying 2.5 hours for the rear and 3 hours for the front for a GM 10 bolt 8.5. He charges $45 per hour so I know where I am going.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
