Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-25-2011, 03:19 AM   #1
Handfull 54
Handfull 54's Avatar
Stereo Problem in my 54
I just installed an Alpine 9886 stereo and a KTP 445 amp. The stereo plays fine when the truck is parked but the radio cuts out for a second several times when I'm driving,. The radio itself stays on just the music or voice cuts out. I am using two Alpine 5" speakers in the doors. I have 2 6x9 speakers for the back but have not hooked them up yet as I am getting the upholstery done soon. Any suggestions on where to start?. I wiggled all the wires while parked in the garage but it plays fine. Take it out and a block later it cuts out. I've hooked up several stereos in the past with no problems, so I'm a little puzzled this time. I have the antenna bolted to a bracket on the frame between the cab and the bed and a small foam ball on the antenna half way down the antenna so it won't hit the body. I am going to try a Cd next to elimenate the antenna. Thanks in advance for any help.
Dave in California
Handfull 54 is offline   Reply With Quote
Old 09-25-2011, 03:23 AM   #2
77chris03
77chris03's Avatar
Re: Stereo Problem in my 54
Sounds like a loose wire under the dash
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 09-27-2011, 05:20 PM   #3
Handfull 54
After exhausting all efforts I took the radio back to Alpine. They will check it for me and fix whatever is wrong. One thing I did find out is if you use their KTP-445 amp, it must be used with 4 speakers. That is why it was clipping when I turned up the volume. I cannot repeat all the technical stuff cause I don't remember it all but this amp knows how many speakers are hooked up to it and wants 4 speakers to drive and NOT 2. Thought I would pass this along.
Old 10-01-2011, 03:58 AM   #4
Handfull 54
The nice people at Alpine called me to say there is nothing wrong with my 9886 model radio. So I went to their facility in Torrance, CA. and picked it up. The technician gave me another radio harness and told me to try it out. I went home and hooked up the radio with the new harness which is the same as the harness I already had and it works great. Remember this was a brand new radio that had been sitting in my closet for 2 years. Go figure.
Old 10-02-2011, 02:39 PM   #5
AceX
>130dB Moderator
AceX's Avatar
Loose pin in the harness it sounds like.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
