Old 09-25-2011, 09:32 AM   #1
Steve Hafner
Steve Hafner's Avatar
TWO Questions about A/C Compressors and brackets
The first question is: Who sells the "small" A/C compressor that's painted BLACK, in the first picture below ?
The second question is: What front, A/C bracket is pictured in the other two pictures ? The bracket I have on my original 70 350, is a lot bigger and hides the entire front of the valve cover. I seem to remember reading that there are two different brackets for two different water pumps. That small bracket seems to just attach to the head though. ( I'm going to have to re-install my large, DEAD, original A/C compressor for a while until I can buy all of the stuff to change it over - it just won't have a belt on it ) I'd like to use the smaller bracket, if possible.
I'M CONFUSED !!!
Steve Hafner is offline   Reply With Quote
Old 09-25-2011, 10:16 AM   #2
CharlieBrown
CharlieBrown's Avatar
Re: TWO Questions about A/C Compressors and brackets
the compressor is a "A-6"...any parts store carrys them
the last picture is missing the bracket that is in the first picture...it bolts to the intake and water pump along with the compressor
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 09-25-2011, 10:22 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: TWO Questions about A/C Compressors and brackets
I have no clue to your 1st question. I have never seen one that small.
The second one is a factory setup. The third picture is missing parts.
Here is my old complete setup.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-25-2011, 10:57 AM   #4
Livrat
Member #1049
Livrat's Avatar
I think the compressor in the first picture is the standard "A6" compressor, I think its an "optical illusion" making it look smaller than the others.
If your AC mounting bracket covers the entire front of the valve cover, It sounds as if you have the early brackets usually only used up to 1967 on the trucks, Sorry I do not have any pictures to compare the two styles of brackets
Livrat is offline   Reply With Quote
Old 09-25-2011, 11:11 AM   #5
Steve Hafner
Here is a picture of "MY" 350 engine compartment ( with the compressor missing ) with the bracket that hides the front of the valve cover.
Old 09-25-2011, 11:19 AM   #6
Steve Hafner
Here's the 67 bracket - it's different then the other's I've posted.
Old 09-25-2011, 11:27 AM   #7
Andy4639
Old member
Andy4639's Avatar
Question Re: TWO Questions about A/C Compressors and brackets
This picture looks like it's missing the stock front bracket as well. It's not going to run long without it if it is. It does look like it has a lower bracket fitted to it though maybe.
If my memory serves me right the smaller brackets are for later model trucks. 70-72.
Old 09-25-2011, 11:28 AM   #8
Steve Hafner
Here's a working 350 in a 72 with the small bracket too:
Old 09-25-2011, 11:42 AM   #9
Livrat
Member #1049
Livrat's Avatar
All of the pictures you posted except "your" setup (which is correct) are missing the factory upper front adjuster bracket, (quite common).
Early 60's passenger cars and Corvette used a thin upper adjuster similiar to a 67-68 upper alternator bracket
These are the factory correct brackets for your truck
http://cgi.ebay.com/ebaymotors/67-72...item4cf998889a
These are the early passenger car and Corvette brackets (you can see the long thin upper adjuster)
http://cgi.ebay.com/ebaymotors/1964-...item5d30798213
Old 09-25-2011, 11:50 AM   #10
Steve Hafner
Below, is a link to a previous thread that was discussing this "KINDA", where the last post has a picture of another one without the BIG bracket.
http://67-72chevytrucks.com/vboard/s...d.php?t=130114
Old 09-25-2011, 11:53 AM   #11
Steve Hafner
SO, it wouldn't be correct for my 70, but I could use the early 67-68 style bracket instead of the one I have ?
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Old 09-25-2011, 12:16 PM   #12
Livrat
Member #1049
Livrat's Avatar
I am not sure if the 67-68 bracket would work as it was originally bolted to the big stamped steel bracket, if it lines up with a water pump bolt hole or a head bolt hole then maybe.
Here are a couple of picture of the passenger car adjusters.
http://www.autopartsobsolete.com/car...popup&id=11038
http://pic100.picturetrail.com/VOL68.../394498485.jpg
http://www.jims59.com/65impala/image...SSengineRt.jpg
Old 09-25-2011, 12:44 PM   #13
Steve Hafner
I was hoping that one of these would work - this bracket is not strong enough to hold the front of the compressor by itself ?
Old 09-25-2011, 12:52 PM   #14
RichardJ
Early V8 heads don't have the mounting pad and threaded holes on the front of the heads. The big brackets were needed to attach to the water pump and intake bolts on the old heads.
http://www.fastnuf.com/Headguide.html
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 09-25-2011, 12:53 PM   #15
Livrat
Member #1049
Livrat's Avatar
I cannot say for sure what the long term effects of not having the adjuster in question would be, it is a quite commonly missing item and I have seen many still functioning with out it.
Old 09-25-2011, 01:07 PM   #16
Steve Hafner
This engine is said to be a 71 - here's another picture of it NOT "zoomed in"
This is the bracket I'd like to use, UNLESS the compressor is going to fall off !!!
Wouldn't my 70's head have this same threaded hole in it ?
( I'm not near my truck, or I'd go look )
Old 09-25-2011, 02:18 PM   #17
Andy4639
Old member
Andy4639's Avatar
Most heads do have the bolt holes in the heads but some don't.
Old 09-25-2011, 02:33 PM   #18
Steve Hafner
I guess I'll have to wait until I get the truck back home ( MAYBE next weekend !!! ) and see what I have and go from there.
As far as the smaller compressor goes, below is a "Sanden" compressor from a thread I found on this website.
Is THIS the smaller type. I haven't seen one of these in black though - do they come in black ? Who sells black ones ?
Old 09-25-2011, 03:41 PM   #19
Andy4639
Old member
Andy4639's Avatar
I swapped mine out for this setup about 3 years ago now with nop problems.
Old 09-25-2011, 04:31 PM   #20
Flint70step
Flint70step's Avatar
Paint it black?Scuff it up a bit and use some quality paint and bet it will look great.Just my 2 cents
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 09-25-2011, 06:08 PM   #21
Andy4639
Old member
Andy4639's Avatar
I haven't ever seen a black one.
That doesn't mean they don't have them though!
Old 09-25-2011, 06:21 PM   #22
Steve Hafner
There was a black one on here - it might have been painted though and OF COURSE, I can't find it now !!!
Old 09-25-2011, 06:47 PM   #23
Livrat
Member #1049
Livrat's Avatar
I too have never seen a black one, either dull aluminum or polished,
One thing to keep in mind if you go to the Sanden compressor the factory mounting brackets will not work, your hoses will also not work, you will have to use aftermarket, I do believe the ones shown are "Vintage air" setups.
Old 09-25-2011, 07:24 PM   #24
Steve Hafner
The front bracket on this one will work good.
I have to get all new hoses anyway, when I change it over, mine are ALL 41 years old and haven't been used in probably 25 years.
a/c brackets, a/c compressor
