Old 04-13-2003, 01:35 AM   #1
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
HEI Distributer Conversion Wiring
I just put an HEI distributer in my grandfathers old '70 Chevy pickup that I own and was wondering what is the best (Simplest) way to wire it in correctly to the ignition switch. I think I read somewhere before that the stock wire isn't a heavy enough gage wire and a new one would need to ran. I temporarily ran a hot from the battery to make sure it would run with the new distributer. Now I want to wire it up correctly. Any help, link or a simple schematic would be appreciated.
Thanks, Roberty
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 04-13-2003, 01:45 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You are right on the stock wires, clip them out, including the yellow one going to the starter.
Just run a wire to the IGN UNFUSED terminal on the fuse box.
Old 04-13-2003, 10:04 AM   #3
Blue Beard
Blue Beard's Avatar
Where can it safely be wiring if the fuse block is full?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-13-2003, 10:08 AM   #4
Longhorn Man
In reality, I like to splice into the large pink wire behind the ignition switch. (that's how I have done 2 out of 3 of my trucks). However, I got flamed on here for sayig that last time.
You can also splice the old coil wire real close to the fire wall where the harness comes out, it is not reduced voltage there...but that looks like poo-poo.
Old 04-13-2003, 10:23 AM   #5
Blue Beard
Blue Beard's Avatar
What is the large pink wire hook too?
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 04-13-2003, 10:33 AM   #6
Roberty
Roberty's Avatar
Ok, I'm still a little confused, Longhornman. I need to run a wire from the IGN Unfused terminal to the distributer - Correct?
What do I need to do to the yellow one going to the starter? From where do I need to run the starter wire from?
Roberty
My vehicles:
'90 Silverado Sport
Old 04-13-2003, 10:44 AM   #7
Longhorn Man
Mr Beard, that wire basicly feeds everything that is controlled from the ignition switch.
Rob, The old points set up was wired 2 ways, the cloth covered reduced voltage wire ran the coil while the engine was running. The yellow wire going to your starter is only hot when you are cranking the engine over. This yellow wire sends a full 12 volts to the coil while cranking the engine over to help with a hotter spark, there for giving quicker start ups.
The HEI makes more power than the old points ever did (in stock form) and does not theed the yellow "boost" wire to assist in anything. The starter only needs the large battery cable, and the purple wire on the S terminal in order to operate.
You got it.
Old 04-13-2003, 11:10 AM   #8
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I'M using the UN_FUSED contact that Andy talked about for my HEI and Electric choke ,used 12 gauge wire and placed a 5 amp fuse in line . Works great .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 04-13-2003, 01:58 PM   #9
baggedblaz
you can pull a factory HEI power wire out of a truck or car that has the correct connector and replace the existing wire in the harness end to end not cutting a thing just plug and play per say
the terminal at the firewall can be swapped pretty easy ? kinda hard to explain if you arent familiar with the connectors and how they come apart??
i've done this to alot of my trucks and friends as well.looks and works great!
'82 chev swb 4dr 2wd project
'72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's
'71 2wd blazer
'95 chev 2wd Xcab swb
baggedblaz is offline   Reply With Quote
Old 04-13-2003, 02:17 PM   #10
72MARIO
72MARIO's Avatar
Longhorn.
They way you described will work. I want to make you aware of the fact that if you remove the old resistor wire and run the correct gauge wire required for the HEI (I forget the gauge 12 sounds right) from where the Old resistor wire plug in you will have the required 12 volts. Just another way Kinda a clean stock looking conversion.
This post Love Tip not a I want to piss you off Post.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-13-2003, 06:11 PM   #11
Roberty
Roberty's Avatar
Whew - Thanks for all the responses on the HEI conversion guys!! I really appreciate it.
Roberty
My vehicles:
'90 Silverado Sport
Old 04-13-2003, 07:49 PM   #12
Longhorn Man
72MARIO, i have never seen anyone pull wires out of the block, only bulky crimp on fittings there, thats what I was saying looked like poo-poo.
You ain't tickin me off. If I'm wrong or don't know the whole story, speak up. I've been called Obie one truck-nobie on here, but I learned 75% of my truck knowledge on these pages. I just remember what all y'all say and repeat it.
