09-25-2011, 02:05 PM | #1 |
Disastrous Day!
After working many hard hours,I thought today I might finally be able to drive my truck. So I went and bought a new 5 gallon gas can. As I was filling it up the top plastic ext. hose came off and went right down into my gas tank, My heart sunk! I said heck I might as well drive this,so started it then backed up,right over my new GMPP air cleaner. I was pretty sick,so I just came in!
Do you think I have to take the gas tank out? |
09-25-2011, 02:16 PM | #2 |
Re: Disastrous Day!
I would take out the fuel filter float a d see if I could reach I thru there
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-25-2011, 02:31 PM | #3 | |
Junior Member
Re: Disastrous Day!
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-25-2011, 03:20 PM | #4 |
Re: Disastrous Day!
When getting my truck ready it took at least three solid weekends of work so hang in there
1969 Chevy c20(Miss Hackjob) |
09-25-2011, 07:02 PM | #5 |
Re: Disastrous Day!
This probably won't make you feel any better but I tell my dad when we have a ruff time at the shop,"if it were easy everybody would do it". Meaning not everyone has the ablity to work on these things. I was in a bookstore once looking for some reference books and these two guys were standing and talking about these cars in this book and how they would love to get their hands dirty. I told them I rebuilt wrecks and restored musclecars and had a body shop. These guys were lawyers and made 100's of thousands a year and said they would trade it all to be able to do what I do for a living. One other and this might help, I was at the dragsone time my ol chevelle giving me the blues aold timer 70's-80;s walked up and said feller if it's got tires on it or boobies [he used a T word] if will cause trouble
09-26-2011, 12:19 AM | #6 |
Re: Disastrous Day!
man that sound like my dumb luck...... it will be worth it in the end...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
09-26-2011, 06:34 AM | #7 |
Re: Disastrous Day!
Thanks for the kind words guys!
Would you guys remove the gas tank to get the plastic hose out? |
09-26-2011, 07:42 AM | #8 |
Re: Disastrous Day!
I would try and fish it out, if it was me the plastic would disintegrate and plug the fuel filter when I am the farthest from any cell phone coverage and home.
I just thought of something ! Maybe that plastic will float fill the tank and you might be able to get it!. |
09-26-2011, 10:28 AM | #9 |
Florida Edition
Re: Disastrous Day!
Fill er up about 3/4 full then jack up the right side, it should float up where you can get at it with a coat hanger and flashlight.
Good luck.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-26-2011, 12:03 PM | #10 |
Re: Disastrous Day!
Ya I think you can just fish it out. If tank filler is to hard to use through that hole you can try to take the sending unit out if you can get at it better.
09-26-2011, 12:15 PM | #11 |
Re: Disastrous Day!
maybe it sounds like you need to go fishing...
09-26-2011, 03:47 PM | #12 |
Re: Disastrous Day!
I have a gas can that's over 20 years old. True, the hose hasn't been sitting in the gas the whole time, but I really don't think it's going to dissolve. I wouldn't worry too much, unless it gets tangled up in your sending unit.
09-26-2011, 03:53 PM | #13 |
Re: Disastrous Day!
The plastic fuel tank's sole job in life is to hold and dispense fuel, I would think it would not disintegrate when submerged in it.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-26-2011, 05:18 PM | #14 |
Re: Disastrous Day!
I agree with filling it up, jacking the passenger side. With one exception. Get one of those red grabber thingys (not the technical name). Im sure you have seen them before, they are flexable about 3 foot long when you push the button on the handle end little wire claws come out.Good Luck. found a pic
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
09-26-2011, 05:29 PM | #15 |
Junior Member
Re: Disastrous Day!
I had part of the gas station rubber nozzle come off in my tank. I would get it out of there. You can drain the gas get it out and have the gas tank bak in in less than an hour. The gas station paid me $600 for this since they knew it was bad and did not repair the nozzle. Only 8 bolts holding the tank along with the eight for the seat.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
