MOTORHEAD!
transmission crossmember?
Does anybody make an aftermarket one for a 81-87 application?
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
Re: transmission crossmember?
Yours rotted out?
I have seen some aftermarket crossmembers on websites that sell suspension parts. Cant remember where. I'll look
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
MOTORHEAD!
Not rotted out, but a pain in the butt for doing 3" exhaust... The one above looks like it will solve my problem. Thanks for the link!
I have that one and there is plenty of exhaust clearance above it.
![]() By claypool782 at 2011-06-06 ![]() By claypool782 at 2011-09-01 |
I like the ones built by Early Classic Enterprises & Perf Online because they capture both the top & bottom of the frame rail like a factory unit does to limit frame flex. The universal tubular units will support the trans fine, but they don't help strengthen the frame....
http://www.earlyclassic.com/catalog.aspx http://www.performanceonline.com/196...MEMBER-TCM6372
Factory 73-76 crossmembers dont dip low on the drivers side, they are semetrical and a mirror image of the right side of your current cross member.
John 82 Chevy Silverado 350ci/TH350 ![]() |
They still had them beyond that time on anything that didn't have to have a catalytic converter on it, which is heavy duty half tons and up. I'm not sure when or if the emissions laws started to tighten up but I know trucks with higher GVWR's didn't need them.
1977 GMC Sierra Grande |
#9 | |
Does anyone make one for an 81-87 manual trans? I'm having the same problem you are and can not fit the exhaust I have.
![]() Join Date: Apr 2011
I'm on the hunt for a new crossmember for my 5.3/4L60E swap, and I like the Early Classic/Perf. Online setup with the frame bracket setup, but it says they're for 67-72's - will it still fit on 73-87?
I'd re-use my crossmember, but it doesn't have the dual frame support brackets - it only has the brackets on the right and then it slings under the frame and bolts up on the outside of the frame rails - probably because it was an '80 emissions-equipped 1/2 ton
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
#12 | |
I used one of these for my CC dually w/a 454/th400 combo after slightly modifying it for the taller rails & making a new mounting pad.
#13 |
The Thorbecke Bro's one is awesome, I have one too
#14 |
Thanks Scoti, for the recommendation and link for a crossmember you gave back in September. I just ordered one.
#15 |
Why do you think the ECE crossmember costs $20 more than the performance online crossmember?
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
#16 |
BAD BOW-Silverado XST
#17 |
Does that hang below the frame?
#18 |
#19 |
What do you guys think of this unit that i have fab'd up , fully boxed the frame woth some channel i had made at a local welding shop , i did so because i found it will make for easyer removal later on. Hope ot works !
1986 LWB c10 w/327 & vortec heads ![]() Last edited by i heart square bodys; 09-14-2014 at 01:59 AM. Reason: spelling |
#20 |
Looks good to go.
