09-25-2011, 07:57 PM | #1 |
LMC Power Window Kit
I recievew the LMC power window kit for my 65 C10 as a gift recently. Has anyone used this kit and if so what did you think of it?
Thanks Posted via Mobile Device |
09-26-2011, 04:05 PM | #2 |
Re: LMC Power Window Kit
If it is the universal kit that uses cables I put one on one time. It was a chore putting it on. It uses the original window regulators so you want them to be in good shape & roll up & down easily. It worked good & was rewarding. You will just have to take your time.
09-27-2011, 12:00 AM | #3 |
I installed one on a customers truck that he had allready purchased that replaces the crank handle. It was super cheesy. It had a little plastic cover to go over the spooned shaft and a very unstable mount system for the motor end. I reccomend either using the ez wire window kit or the specialty power kit. Ez wire is a bit more economical. Not sure which one you have for sure though, maybe throw up a pic or link to the product for a little better feed back.
Check out my build thread for my '63: http://67-72chevytrucks.com/vboard/s...49#post4806049 |
