Old 09-25-2011, 08:14 PM   #1
dukcaln
dukcaln's Avatar
vacuum leak/ vacuum hose help, urgent
so I started the truck up today after driving it last night with no issues.... I got about 30 seconds in the warm up of the motor and heard kinda a pop followed by what sounds like a bad vacuum leak.... so i stopped the motor and took the cleaner off and noticed the below (see picture). what connects to that and shouldn't there be something..... maybe plugged off. I couldn't find anything else
also where does this hose plug into, its been plugged since I got the truck.. mabe I need to get it plugged up in the right spot...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 09-25-2011, 08:43 PM   #2
71 super
71 super's Avatar
Re: vacuum leak/ vacuum hose help, urgent
The intake port is a take off for a/c- do you have a/c? if not block it off and call it good-I guess some one have been using it for power brakes as well. If you have neither block it and call it good. The port on the carb is a full vacuum port that attaches to the breather for the cold air pull off on the snorkle. Again if no stock breather it is not needed and can be blocked as well.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-26-2011, 12:10 AM   #3
dukcaln
dukcaln's Avatar
thanks .... I found a plug that must have came of the port..... so I reattached it and secured it better then I blocked off the other one and started the truck back up..... seems to be running good agai... that was weird ... for it to all of a sudden come off... man it sounded like a big vacuum leak and stumbled like crazy.... never the less glad to have it running again
SOLD 1972 chevy c10
Old 09-26-2011, 01:07 AM   #4
domeier
domeier's Avatar
Don't park that truck anywhere close to Scoggins/Markham is you don't want it to disappear! I built the Lincoln Corner guvmint subtuhdized apartments there. I apologize.
domeier is offline   Reply With Quote
Old 09-26-2011, 12:14 PM   #5
dukcaln
dukcaln's Avatar
yea, thanks..... I hear ya... been here many years and of course I know it all too well..
SOLD 1972 chevy c10
