Old 09-25-2011, 08:15 PM   #1
Legolas894
Chemist under the hood...
Legolas894's Avatar
Fixed Bench to Tilt Bench
I've been looking to replace my old tilting bench seat for some time now as it's shot ont he drivers side. As luck would have it, I found a beautiful bench seat sitting out for the garbage last week. It's in much better shape upholstery-wise and doesn't have that old-chinese-food odor that my current seat has. The only downside is that it's a fixed bench (no pivot).
My questions are-Would you go to a fixed bench? (What am I sacrificing) and can I convert the fixed to the tilt using hardware of the old one.
Thanks in advance.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 09-25-2011, 08:51 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Fixed Bench to Tilt Bench
Most 68 and all the following years had seats that the backs did not tilt. As long as you stay in the 67-72 years the seats should be a bolt in.
I put a '92 bench seat in a '72 years ago and it fit good, but I did have to drill some additional holes and put plates under the cab to add strength to the floor.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-26-2011, 10:09 AM   #3
turp mcspray
turp mcspray's Avatar
They are easily converted so they will tilt. They went to the non tilt as a safety thing.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-26-2011, 07:12 PM   #4
Legolas894
Legolas894's Avatar
The seat I found is correct for '67-72 and I don't mind just putting it in I just wanted to know if there's an issue later on with getting to the gas tank to replace the sending unit etc. Did they make the seat slide forward more than the tilter? With the in-cab tank, there really wasn't much room and I wondered why they put a tilting seat in when you really can't put much behind the seat.
Current fleet:
Old 09-26-2011, 08:58 PM   #5
57larry
how do you make them tilt?
57larry is offline   Reply With Quote
Old 09-26-2011, 09:20 PM   #6
turp mcspray
Seems like there is a couple of bolts in the side of the upper seat frame. I think I just removed the upper bolt, tilted the seat ahead, and then replaced the bolt while adding a nut to tighten it up against the seat frame, allowing the seat back to rest against it. I did this like 10 plus years ago, so this description is just from memory.
Turp Mcspray
Old 09-26-2011, 10:06 PM   #7
Legolas894
Legolas894's Avatar
There's an old thread on here where someone recommended cutting a slot on the upper bolt so that it would rest on the bracket when upright but could be tilted forward as there was no stop for the bolt.
If most people have fixed seats, I can install as-is. The uphostery is good and the bracket is completely covered with the vinyl. On my tilt bench, the bracket is exposed.
Current fleet:
Old 09-26-2011, 11:06 PM   #8
bigbadchev72
People know me
bigbadchev72's Avatar
X2 mine is the same way.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-27-2011, 12:15 AM   #9
57larry
a pic would help my dumb ---
