09-25-2011, 10:57 PM | #1 |
MOTORHEAD!
1982 relocate leafs....
i have a 82 GMC.... How do you relocate the leafs to allow a super wide tire? Does anyone make a kit for doing so??
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
09-25-2011, 11:59 PM | #2 | |
Re: 1982 relocate leafs....
You can box the inside sections of the frame rails where the hangers are & flip the hangers/mounts from side to side (driver side mounts get moved to inside of the pass side rail).
