Old 09-25-2011, 11:29 PM   #1
k1rodeoboater
exhaust system ideas...
I need a new exhaust from the manifold back. I'm contemplating building it all myself, but I've never done anything like this before. I've got a MIG, grinder, and some degree of common sense. What all do I need to know and have to build a full manifold back exhaust system.
I know I'll need an assortment of bends, but what will I need to connect to the stock exhaust manifold?
I know for a fact I don't want a glasspack, it's what I have currently dumping out under the drivers step and I hate how loud it is and the drone in the cab. I'd love to run it out the back but my camaro tank is in the way. What I'm thinking is running it out behind the rear tire under the fender. Here's a few pics so you can see the tank
I've got a stock 250 I6 in the truck. I'd rather do this cheap if I can because I eventually will either be getting headers or swaping engines down the line...that and it's more fun to learn how to do something new.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 09-26-2011, 12:02 AM   #2
tooslo60
tooslo60's Avatar
Re: exhaust system ideas...
Exuahst? Mufflers? Just run open headers!!! LOL
Andy
tooslo60 is offline   Reply With Quote
Old 09-26-2011, 12:31 AM   #3
Captainfab
60-66 Nut
The hard part will be the pipe from the manifold down. Have you checked with your local auot parts supplier, for a stock replacement pipe for a 250 I6? id doesn't have to be for your year truck, the 250's were used in the square bodies into the early to mid 80's IIRC
Old 09-26-2011, 12:59 AM   #4
S-31
You can buy the whole exhaust system for your truck from the manifold back from Advance auto parts, prebent, and bolt it on in an hour or so. It is probably somewhere in the neighborhood of $150 dollars. Or you could get the bends and pipe from somewhere like speedway and cut and weld everything yourself and it might be a few dollars cheaper, but spend the better part of a day(or more) cutting and welding and laying up under the truck. The cheapest option would be to just cut out the glasspack and put in a quiet muffler until you decide which engine you are going to drop in, and just drive it like that until you decide.
S-31 is offline   Reply With Quote
Old 09-26-2011, 08:51 AM   #5
Crash'd Artwerks
I took my truck to the local exhaust shop and had them run a single 2.5" pipe from the y-pipe out the back. It has a 24" glass pack and sounds pretty good. It's not loud at all. When you get on the gas, you can hear it though.
Cost me $175 and a couple hours of wait time.
But, if you wanted to do it yourself, the best way to do it would be to go to the exhaust shop nearest you and see if you can buy some bends that they have laying around in the scrap pile that they didn't/couldn't use. Then buy some straight pipe and get to welding.
-Aaron
Crash'd Artwerks is offline   Reply With Quote
Old 09-26-2011, 12:59 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
the noise isn't terrible as long as she kicks into o/d on the hwy
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-26-2011, 11:56 PM   #7
MisterC
MisterC's Avatar
I'm a fan of running the exhaust all of the way out the back. Along those lines, I'd love to see some examples of different styles of chrome exhaust tips that you guys have used.
I'm partial to the round tips, but find they hang down a bit too far below the stock bumper.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 09-27-2011, 03:33 PM   #8
jimmydean
jimmydean's Avatar
When we did my buddies square body, we built the whole thing out of 2.5" PVC until we had it perfect, then bought tubes from speedway both pre-bent and straight and welded it up with some quiet pack mufflers. Worked awesome.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
