Old 09-26-2011, 12:39 AM   #1
slick copper
slick copper's Avatar
Red face Factory Sway Bar Install help
Just bought a used factory sway bar off of here and need some help. My truck doesnt' have a sway bar, and wanted to improve the handling. The front end dips pretty bad in corners.
Would like some pics/info on mounting location of swaybar! And of installed sway bar. Any help will be greatly appreciated!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 09-26-2011, 01:17 AM   #2
72gmcshorty
72gmcshorty's Avatar
Re: Factory Sway Bar Install help
just like this.....
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 09-26-2011, 03:49 AM   #3
slick copper
Thanks! Need a few more angles though. That's a good start! Also would the bolt holes already be in my frame? Or will I have to drill?!
Raymond
Old 09-26-2011, 07:48 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Factory Sway Bar Install help
This is my 71 front bar.
I had to drill 2 holes I think. It's been awhile.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-26-2011, 12:10 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Everything you need to know right here....
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Old 09-26-2011, 01:25 PM   #6
SCOTI
SCOTI's Avatar
^^ Great write-up!! ^^
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-27-2011, 04:42 AM   #7
slick copper
Thanks! Exactly what I needed! Thanks everyone!
Raymond
Old 09-30-2011, 06:36 AM   #8
slick copper
Got another question! In that thread some mentioned they bolted it directly to the frame. Is that ok? Would it cause any problems?
Raymond
Old 09-30-2011, 10:32 AM   #9
6772owner
Gearhead
6772owner's Avatar
To my knowledge, directly to the frame is mostly for lowered trucks, you want the sway bar to stay somewhat "level" with the frame. Im not sure how much lowering it requires to go directly to the frame, I am using the Early Classic "lowered" mounting brackets for my sway bar currently.
I may go straight to the frame after I get drop spindles and re-configure my lower control arm/air bag situation....
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-30-2011, 10:48 AM   #10
kieth
kieth's Avatar
Drop spindles should not change the sway bar but the air bags and cups will later on. Kieth
kieth is offline   Reply With Quote
Old 09-30-2011, 12:56 PM   #11
6772owner
Gearhead
6772owner's Avatar
I agree, I guess I should've have stated that it was mostly due to changing the lower arms and the about of drop I will have at the arms when aired out. (Which should be better with the drop spindles because of my unique set up currently)
Thank you for clarifying/correcting me!!
Old 09-30-2011, 02:52 PM   #12
slick copper
So since I'm gonna keep stock hieght ( I think anyway) May do 1" drop springs. I don't wanna go too low, just the style I'm going for. I should use the Factory brackets, or at least ECE brackets?
Raymond
Old 09-30-2011, 06:16 PM   #13
6772owner
Gearhead
6772owner's Avatar
I would say so, I think it would be hard to mount the bar at stock height straight to the frame. The ECE brackets are about half the "height" (drop really) of the stock bracket I beleive. Some else can probably confirm this as well....
Old 09-30-2011, 11:00 PM   #14
SCOTI
SCOTI's Avatar
ECE brackets are about 1/2 the height of the stock units.
Mounting directly to the frame is about the same amount of change.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-01-2011, 12:07 AM   #15
slick copper
Thanks guys! I think that clears it up! I'll use the stock brackets for now, if I drop I'll get ECE brackets!
Raymond
Old 10-12-2011, 06:04 AM   #16
slick copper
Going to get bolts to bolt my swaybar up. Anyone know what length to use? I know I need grade 8 bolts and I think 3/8" in diameter.
Raymond
Old 10-12-2011, 09:09 AM   #17
71tahoe
71tahoe's Avatar
3/8 x 1 will work but you will need to use longer ones to get the bushings compressed first. Or just use the longer ones but extra thread sticking out is one of my pet peaves.
71tahoe is offline   Reply With Quote
Old 10-12-2011, 01:08 PM   #18
slick copper
Thanks! Yeah, I'm the same way!
Raymond
