Old 09-26-2011, 01:06 PM   #1
MalibuKasey
Artist
MalibuKasey's Avatar
Weird brake problem
So if I let the truck sit for a few days and go to drive it.. the first time I put the brakes on it locks the rears up. If I pump them up it solves the problem and they work fine... any thoughts? It has a CPP powerbrake setup on it with a front disk conversion from a 78 silverado.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 09-26-2011, 03:31 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Weird brake problem
How does the peddle feel, nice and firm or soft? Using (losing) any fluid? Have you thoroughly bled all four courners? Bled the MC? I would also take a look at the rear linings and drums.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 09-26-2011, 03:59 PM   #3
Wrenchbender Ret
You could be leaking fluid or grease on the drum.
Wrenchbender Ret is offline   Reply With Quote
