Old 09-26-2011, 02:49 PM   #1
2mas
Question Engine stop
Hi all!
New intake and outlet manifold! Happy on the test drive...
...engine stops after a 20minutes drive and will only re-start
with the choke control out. As I touch the gaspedal it dies.
Its a I6 230 1965.
Any one that could point me in the right direction?
Thanks! /2mas
2mas is offline   Reply With Quote
Old 09-26-2011, 04:28 PM   #2
k1rodeoboater
Re: Engine stop
Electric fan?
Aftermarket intake and exhaust?
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 09-26-2011, 05:43 PM   #3
Vernski
Re: Engine stop
Originally Posted by 2mas View Post
Hi all!
Its a I6 230 1965.
Thanks! /2mas
Sounds like the carb is plugged up if it will run with the choke out. Is it the stock Rochester? Check the fuel filter inside the brass feral where the fuel line goes in....Vernski
Vernski is offline   Reply With Quote
Old 09-26-2011, 06:11 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
Re: Engine stop
Sounds like you might have a vacuum leak.
Old 09-26-2011, 06:11 PM   #5
pdxhall
pdxhall's Avatar
Re: Engine stop
Hi all!
Its a I6 230 1965.
Thanks! /2mas
You might also check if your fuel line might be running too close to the exhaust header or engine block causing the gas to percolate in the carb.
pdxhall is offline   Reply With Quote
Old 09-27-2011, 01:11 AM   #6
2mas
Re: Engine stop
Ok! I'll check this out. Feral? Is that in the carb? (sorry technical english is a bit tricky for this swede... :-) )
I've been looking for som kind of filter, but I can not find any near the fuel tank or on the fuel line.
The truck is completely standard, manifolds, carb, etc.
/2mas
Old 09-27-2011, 10:14 AM   #7
steverino66
Re: Engine stop
disconnect the gas line at the carb end and look inside the fitting on the carb side
steverino66 is offline   Reply With Quote
Old 09-27-2011, 04:18 PM   #8
2mas
Re: Engine stop
Removed the filter in the carb... See pic.
Fired the motor up with out filter! Works fine.
Thanks for the help.
Just hope that my fourth testdrive will not end with a tow.
/2mas
Old 09-27-2011, 10:26 PM   #9
Vernski
Re: Engine stop
2mas you need to replace the filter or clean out the old one, I haven't seen one like you have they are a cone shaped fine mesh that inserts in the fitting in any case you need to either replace it or clean it there may be more stuff lurking in the tank it will plug up the whole carburetor without it. Then you will have to take it apart and blow with air hose to get it cleaned out good luck...Vernski
Old 09-28-2011, 02:40 PM   #10
2mas
Re: Engine stop
Any one got a pic on how it should look like?
I will try to get one localy in Sweden.
thx /2mas
Old 09-28-2011, 04:23 PM   #11
Vernski
Re: Engine stop
thx /2mas
Hi 2mas here is some pictures of the filter...Vernski
Old 09-29-2011, 04:52 PM   #12
2mas
Re: Engine stop
Thanks!
/2mas
