12 bolt ID
12 BOLT rearend ID.
These numbers are located on the axle tubes on a 5 Lug Rear from a 6 Cyl 1971 chevy S/B truck. D242 1234567890 CON2 No other tags or ID marks on this thing. If you know how to ID this it will help me thanks.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: 12 bolt ID
pic if it helps
member #16
![]() Join Date: Dec 1999
Re: 12 bolt ID
The code numbers are stamped on the pass side axle tube on the top side. they aren't always stamped very deep, so you need to wire brush the tube to find them.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Re: 12 bolt ID
It's good to decode the stampings to see what the truck was born with. Just don't assume that's what's in it now.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: 12 bolt ID
Here is a copy of what another member wrote in another thread on here I copy and pasted into a word doc I cant remember who did it but it is accurate.
C10 Rear axle codes "I found some axle codes. The code is stamped on the top passenger side axle tube. The code on my rear end reads HB 03 25 W. The HB is the gear ratio, 03 is the month it was built and the 25 is the day. These codes are for the C-10 series. " HB,LL,RA.TR,TT,TU are 3.07s HA,HJ,HQ,MF,TQ,MI,MK are 3.73s HK,HL,HR,ME,MG,TS are 4.11s HC,HN,MU are 3.73 Posi HO,HP,JQ, are 4.11 Posi |
Re: 12 bolt ID
subscribed
Re: 12 bolt ID
Interesting, done brushing, cleaning and found this: on R/H upper side of Tube:
RHC W144 2 Does this mean it's a posi 373? If so I'll be stoked..Interesting as the truck was a plain jane 71 6 Cyl truck with only two items on the spid: Red/white paint & Gage cluster. Didn't even have a Cig lighter just the delete plug in the dash. Whatever I got a good deal for a $50 bill.
Junior Member
Re: 12 bolt ID
Subscribed
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
Re: 12 bolt ID
I looked all over the place on the www didn't find the codes listed by LONGBED67. Plenty of other stuff just nothing corresponding to my codes (RHC). Jacking one side up attempting to spin a wheel is a no go. I will assume it's a posi. Will know more once the cover comes off for fluid change.
member #16
Re: 12 bolt ID
My book shows RHC as a 1972 3.73:1 ratio. The 1971 ratios all start with the letter "T".
Re: 12 bolt ID
Yes should be a 3.73 posi unless someone changed the guts
Junior Member
Re: 12 bolt ID
How does one decode the stamping after after the ratio code? I assume that's the date? I have one stamped "HC" (with an E) below it and what looks like "1027K" after. 3.73 posi is still in it and was told it's a '68. It's narrow. I have a pic but can't post from my Droid.
#13 |
Junior Member
Re: 12 bolt ID
Pic. Sammy, Hope it's Ok if I kind of hyjack this thread. I can confirm another HC coded 3.73 posi. I reread posts closer and see Longbed67 already told us how to decode the month and day. Looks like I have an October, 27th built rear but what's the year? Does the "K" indicate that somehow? ..and Sammy's "W144 2" doesn't seem to compute.
#14 |
Re: 12 bolt ID
From another site I gathered W was a plant manufactures code 1 was last digit of the year and 44 th day of production and 2 as 2nd shift. But who knows. Most important for me was the gear ratio..and the year of 71 which I knew as I removed it.
Your "K" doesn't make any since to me at the end..My W is in the front..unless they just put them anywhere to indicate the plant assy point. Hijacking threads are a great way to learn stuff...from each other..so drive on and keep truckin..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 09-30-2011 at 01:41 PM. |
#15 |
VA72C10
![]() Join Date: Mar 2008
Re: 12 bolt ID
Old thread....but What about
HE1 11w Or TDA? Two different axles I have that I can't find the codes listed anywhere... Posted via Mobile Device
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#16 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 12 bolt ID
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#17 |
Re: 12 bolt ID
Got two I need to decode to see which I will keep. One is def posi unsure of other. Can you tell ratio from stampings on ring gear? I seem to recall the guy I bought my 14 bolt from pulled the cover and showed me the 4.10 stamp.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#18 |
Re: 12 bolt ID
Man - I have been searching all over the internet for information about these stamp codes and I just can't find anything. I am looking at an axle from a '65 Chevy pickup that is stamped "WE327" on the tube. I can't find ANY information on that particular code. I want to find out the gear ratio. The axle is fairly far from me or I'd just go take the cover off and find out.
#19 |
Re: 12 bolt ID
Also looking for axle code "TDA"
#20 |
The Older Generation
Re: 12 bolt ID
Look in this thread...
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=578793 The 3 letter codes start with 1970 LockDoc
#21 |
Re: 12 bolt ID
Thank you!
#22 |
Re: 12 bolt ID
