09-26-2011, 07:00 PM | #1 |
trailing arm length
i have a lwb 68 that i plan to cut down to a swb. if i use factory swb trailing arms, can i leave the mounting crossmember where it is?
09-26-2011, 08:30 PM | #2 |
Re: trailing arm length
Trailing arms are same short or long--frame should shorten in front of crossmember---search this site for some threads--I know there here somewhere!!! lol jim
09-27-2011, 11:58 AM | #3 | |
on the older trucks the crossmember on a swb is under the cab, on the lwb truck the crossmember is sitting even with the back of the cab. You better take a good look at a swb 68 before you tackle the cut down, it is not quite as straight forward as it seems. Kieth ps If I was doing it, I would have one sitting next to me when I did the work so you could check the dimensions and locations of everything. Kieth I do not believe it is a problem on the 68 but with our older trucks 66 the axle needs to be centered in the wheel well.(moved back 1.5" |
09-27-2011, 12:44 PM | #4 |
Check out this thread http://67-72chevytrucks.com/vboard/s...d.php?t=123624
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
