73-81 van suspension?
Is the van set-up, besides the steering box of course, the same as the trucks? I found a 77 Chevy van with a 350/th400 running and driving for $600. I need to upgrade my 68 drums to disc and would also like to get power steering/brake/V8/auto. I figure if the van suspension would work I could get all of this in one swoop.
Thanks Posted via Mobile Device
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 73-81 van suspension?
I wish I could tell you for sure,... but I've never done this swap.
I don't even know if the a-arms are the same. Anyone else?
I can't imagine why the truck would be different then the van. Anyone?? Thanks.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
according to Oreilly rotors are the same.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
True, and per this eBay add the control arms are the same:
http://cgi.ebay.com/ebaymotors/Chevy...item48417e6b21
![]() Join Date: Feb 2004
I thin the 73-81 are the same but the older ones had car bolt pattern rotors and were much thinner that the trucks not as heavy duty. I know this because i have a napa brake book that covers up to 71 and I researched this when swapping out my truck parts I ended up with 5on5 truck front and 5 on 4 3/4 car rear pattern I wanted them to match and both be car but there was too much involved in changing the front and i had already bought drop spindles
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
60-66 Nut
![]() ![]() Join Date: Mar 2007
On the '72 and newer full size vans, the control arms and out are the same as the pickups. The crossmember itself is wider than one on a pickup. And as you already mentioned the steering box will not work.
