Painting Master Cylinder
First I know this isn't for my truck but at least its a chevy! I am painting the master cylinder and steering components on my 67 camaro and want them to look like bare metal but have protection. My question is, has anyone used something out of a rattle can to paint something similar and had good luck with it?
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
Junior Member
Re: Painting Master Cylinder
Eastwood has what you need.
http://www.eastwood.com/ew-brake-gra...sol-13-oz.html They have other products to make the finish look like Aluminum, Steel, Iron, Zinc, Cad, cast, machined, etc. http://www.eastwood.com/ew-underhood-detailing-kit.html Kinda pricey but I have used them for years and always been happy with the finished product. Lots of solid content in the paint so a can goes a long way.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
67-72 parts collector,…
![]() Join Date: Nov 2002
Everything I have used,... has eventually rusted.
Buy an aluminum M/C and be done with rust. http://www.performanceonline.com/HIG...PVS-AMCPVS233/
Frequent Flyer
I have always painted mine with a cast aluminum spray paint.
(I've got to do the one on my new 72 this weekend) |
If you use spray bomb paint ....don't get brake fluid on it or it's more than likely bubble and flake off. Spray can paint is "non catalyzed"...so is not very chemically resistant. If your careful, it is a quick and cheap way to make something pretty though.
Never tried the Eastwood paint, it does say "resistant" to dot 3 fluid, so it may be worth a try. |
use paint for calipers sold in autoparts stores local// it will hold up better for brake parts
1969 Custom 30 wrecker
I used POR metal mask. Supposed to be impervious to fuels & chemicals, not sure on brake fluid though. Stuff isn't cheap but it goes a long way.
It looks just like the bare cast metal though.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Grandpa in the rustmobile...
caliper paint worked good for me too
i was too lazy on this MC and put iton, looked nice outta the box now its rusty
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
the boat guy
[QUOTE=lolife99;4924831]Everything I have used,... has eventually rusted.
Buy an aluminum M/C and be done with rust. [url] actually aluminum oxidizes faster than steel, it's just not as ugly about it. I'd rather paint steel than have to constantly clean or polish aluminum on a driver. I painted my aluminum heads on my 5.3 after 3 years it still looks better than most 3 month old ls swaps.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#10 | |
Frequent Flyer
Painted mine today with "dark cast" paint...
#13 |
Frequent Flyer
Dupli-Color Cast Coat Iron Engine Paint
#14 |
sharp as a marble
![]() Join Date: Jan 2007
POR 15 flat works!! If I have a pic I will post. I use POR15 gray exhaust manifold paint. It will be good for years/
#15 |
Thanks guys! Just got back from a trip.
JWall - I like the look of that Dupi-color, I'm just worried about it holding up to the Brake Fluid. I think I'm going to be careful and give it a try though.
#16 |
What's the best way to prep the cylinder before painting with eastwood brake gray? Was thinking scotch brute pad should do the truck to get rid of the nasty surface rust and possible brake clean and a good wipe down?
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#17 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#18 |
![]() Join Date: Oct 2009
I used clear satin high temp paint. Has lasted for a LITTLE while with no problems, but the jure (me) is still out.... Looks perfectly natural of course, so that's a good.
#19 |
No comments for prep before spray?
#20 |
regardless of what you paint it with, it will need to be cleaned/degreased thoroughly. I use Eastwood's "PRE" before I do stuff like this.
#21 |
Old member
Mine isn't any of the above. I used good old red paint out of the spray can.
I cleaned it good with wire brush and brake cleaner 2 times then let dry for a few days. 2 years now and it looks just as good. The date is correct for this picture. I sprayed it with clear also. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#22 |
That is a BIG Honkin power brake booster!!!!
#23 |
Old member
If your refering to mine it's suppose to be a factory replacement.
#24 |
Would simple green be good enough or does it leave residue behind? I got my spray today ill probably wait till the weekend to mess with it
#25 |
Old member
I would use something a little stronger myself. Mineral spirits would work to I guess. Brake cleaner are like the other's suggested East wood stuff.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-05-2013 at 01:00 AM. |
