Old 09-27-2011, 12:32 AM   #1
NorthstarGMC
I looked all over, how much does a 60-66 1/2 ton weigh?
Search failed me, Google failed me. Maybe you can help. How much does your truck weigh?
I'm guessing about 4000lb?
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 09-27-2011, 12:42 AM   #2
bobber80
Re: I looked all over, how much does a 60-66 1/2 ton weigh?
I went out and looked at the factory tag on my 62 swb it says 5200 lb
bobber80 is offline   Reply With Quote
Old 09-27-2011, 01:03 AM   #3
NorthstarGMC
Is that the GVWR? I found two GVWR's. One for 5000 and one for 7000lbs.
Old 09-27-2011, 01:16 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
This thread should help. My short step weighs about 3700 lbs without people. The 33 gallon fuel tank holds another 200+ lbs:
http://67-72chevytrucks.com/vboard/s...d.php?t=405606
Old 09-27-2011, 08:18 AM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I'm not anywhere near my books but a four wheel drive curb weight..... but then that's GM just being honest.
Old 09-27-2011, 09:12 AM   #6
kieth
kieth's Avatar
G gross
V vehicle
W weight
R Rating
with what mark said you would take
GVWR 5000lbs - Actual Weight 3700lbs + fuel 300lbs = 1000lb payload.--(half ton)
The 7000lb is probably GCWR Gross combined weight rating which would be total vehicle weight and the trailer one is pulling It would be calculated the same way, 7000lbs - (trailer weight 1000 +4000lbs) = payload of the truck and trailer together say 2000 lbs.... Kieth
this actually gets carried further to each axles capacity and the rating of the tires to carry the actual load. Kieth
kieth is offline   Reply With Quote
Old 09-27-2011, 09:19 AM   #7
McCoyAZ
McCoyAZ's Avatar
Right around 4100 pounds depending on what came on the truck, what motor, how much fuel etc, etc.
McCoyAZ is offline   Reply With Quote
Old 09-27-2011, 10:15 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
Took a load of steel to the recycler, empty weight with my butt in the truck was 3,840 lbs `64 short fleetside.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-27-2011, 11:27 PM   #9
NorthstarGMC
I'm trying to determine the adjusted horsepower rating for my engine.
If it was rated for 320hp in a 3960lbs Cadillac, and my GMC weighs 3,435lbs the difference is 525lbs. I'm estimating the Northstar is 200lbs lighter than the 305 V6 that was in it. This gives me an adjusted weight of 3235lbs, a difference of 725lbs.
Just not sure how to plug this in to get the adjusted HP.
Old 09-27-2011, 11:30 PM   #10
TopFuel1966
TopFuel1966's Avatar
I recently had my '66 SWB Fleetside weighed for DMV purposes. 3820 lbs with a half tank of gas.
TopFuel1966 is offline   Reply With Quote
Old 10-01-2011, 03:38 AM   #11
NorthstarGMC
I've heard it's 1hp for every 10lbs dropped roughly. This would mean the HP for the engine is 392hp. Wish there was a dyno around!
