09-27-2011, 12:37 AM | #1 |
Steel rims redrill
I've seen rims cut to go wider and thiner, so why the conflict with redrilling... there has been a few post about redrilling but all I see is NO you can't redrill steel rims... So I figure ill start this one to see what everyone has to say on the subject in one thread....
09-27-2011, 07:24 AM | #2 |
Re: Steel rims redrill
Why would you want to redrill the holes?? Get a set of adapters or order the right rims. Or redrill the drums and flange.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
09-27-2011, 08:33 AM | #3 |
I could but I won't options.... I'm not drag raceing nor pulling 3g,s.... Other forums has may more on the subject than it has here... Just getting more info. Befor I make my mind up...
09-27-2011, 09:31 AM | #4 |
I'm not sure what you have in mind, but the stock bolt holes aren't just drilled through, they are stamped to provide a raised seat for the tapered lug nuts. Just drilling a hole through the hub won't give you the same grip and centering that the stock holes provide. Results could be very dangerous.
09-27-2011, 10:44 AM | #5 |
I'm not. Drilling my rally rims but they are steel... I'm not drilling them out myself.. but there are so great machine shop in the area... Not just so mom and pops
09-27-2011, 10:56 AM | #6 |
It is more than just having a great shop. There need to be the rolled taper seat to lock the lug nut, which machining will not give you. It does not matter how you plan to race the truck or not if the lug nuts will not hold in regular driving (if you have ever had a wheel come off it is an eye raising experience). Redrilling the steel rim is not the way to go, either make adapters (not great), have the axles drilled to the rim s pattern (best), or get rims with the correct pattern.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
09-27-2011, 11:12 AM | #7 |
I dont think i would go there. The wheels are held on by the clamping force of the lugs. The shape of the hole or the "raised portion" has a lot to do with the bolt maintaining that tension. I can relate to the challenge of finding decent steel wheels, but hold out for the right set-up. Youll be happier in the end.
Posted via Mobile Device |
09-27-2011, 11:27 AM | #8 |
If you are feeling the pain of limited wheel choices, have your rotors, axles, and drums re drilled for 5x4.75. You get a lot more wheel options that way.
1977 GMC Sierra Grande |
09-27-2011, 11:45 AM | #9 |
Happy to be here
Why are you so dead set on doing something that everyone's tells you not to do? I'm not sure what other forums you refer to, but I can tell you about this one. In general our Senior members will not recommend any modifications that are potentially unsafe.
Yes you can physically redrill steel rims to fit the bolt pattern and hub diameter. That still does not account for improper seating of the lug nuts. It can be done, but it won't be safe.
09-27-2011, 11:57 AM | #10 |
I'm not dead set on it I just like to know.... that's all
09-27-2011, 12:12 PM | #11 |
Just forget about it..
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
09-27-2011, 12:55 PM | #12 |
Hi--
I don't know anything about this topic, but noticed this ad on Craigslist... ktownkid http://charlotte.craigslist.org/pts/2596373992.html |
09-27-2011, 05:27 PM | #13 | |
John 82 Chevy Silverado 350ci/TH350 |
09-27-2011, 07:40 PM | #14 |
x2.
09-27-2011, 08:13 PM | #15 |
Go ahead...do it.
09-27-2011, 08:34 PM | #16 |
There used to be a shop here and I'm sure there are others out there that can cut out the center section of a steel wheel and weld in a new one. That would be the proper and safe method. Doing it this way you can adjust the offset for a custom application. I had several sets of Rallyes done back when this shop was in Tulsa. They could put in new centers or new outers either one.
09-27-2011, 10:08 PM | #17 | |
09-27-2011, 11:00 PM | #18 |
The place I was referring to was called Fast Wheels, they did a lot of wheels for stock cars, but had rallye centers. I had a set of 4" Rallyes done for the front of my 80 Malibu and a set of 8.5s done for the back. That was probably the place, it was the only one I remember. They did a ton of business, can't imagine why they couldn't make it.
09-27-2011, 11:24 PM | #19 | |
