09-27-2011, 09:35 AM | #1 |
Under Dash Harnesses
I have two very nice underdsah Harnesses, One is from an automatic. It has the two plugs for the neutrl safety switch and reverse lights Not sure if it was in a guagew or dummy lights truck. The second is from a 1971 GMC 4 speed truck with guages. Both are very clean. $125 each shipped
AUTOMATIC HARNESS-SOLD MANUAL HARNESS----Still Available $100.00 Last edited by chevykevy; 02-21-2012 at 09:16 AM. Reason: Update availability of parts |
11-14-2011, 09:13 AM | #2 |
Re: Under Dash Harnesses
ttt
11-25-2011, 06:36 PM | #3 |
ttt
11-25-2011, 09:38 PM | #4 |
Would the 71 work in a 68 K20 std?
1968 K 20 w/327 4bbl 4 sp |
11-26-2011, 12:10 AM | #5 |
I'm not sure. The 67 and 68 fuse blocks are mounted a quarter turn differently. They are the same in everyway, Ithink, except for how they are mounted.
Does anyone else out there know? |
11-26-2011, 12:40 AM | #6 |
Restoration Virgin!
I think the plug for the dash gauges is setup different due if you have dummy lights....but it can be reconfigured using GMC Paul's FAQ for changing the wiring into the plug...easy to do....
not sure on K20 either though
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
11-26-2011, 12:42 AM | #7 |
The 71 , 4 speed harness, is a guages harness.
A harness is made to make it a dumby lights setup? |
11-26-2011, 12:59 AM | #8 |
Restoration Virgin!
no...just the plug that goes into the dash bezel is wired different
11-26-2011, 01:01 AM | #9 |
got ya
11-27-2011, 11:32 AM | #10 |
Ill take the automatic one, if youll do 100 shipped, and questions answered
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-27-2011, 11:49 AM | #11 |
What are your questions?
11-27-2011, 12:10 PM | #12 |
jaros44sr, pm sent
11-27-2011, 02:25 PM | #13 |
Ok, questions answered in pm...does the back of your fuse box look like this, my pink wire is the melted one
11-27-2011, 05:07 PM | #14 |
mine looks like this
11-27-2011, 05:09 PM | #15 |
sorry, heresis the pic
11-27-2011, 06:53 PM | #16 |
Thanks for the pic, how do you want to be paid?
11-28-2011, 11:22 AM | #17 |
Automatic Harnees SOLD
Manual harness with guages still available |
11-28-2011, 12:19 PM | #18 |
re: the manual harness
1) should be the same for a 72 blazer ?? 2) are there any cut/broken wires or missing connectors?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
11-28-2011, 03:25 PM | #19 |
If you buy it, hold your old harness side by side and compare each wire, should be the same, but not totally sure, until you compare
Thanks kevy, just got the delivery confirmation number
11-28-2011, 07:53 PM | #20 |
tjsblazer
I'm not positive about the blazer differences but I would think they would be the same. Is your truck a manual transmission? This harness is for a manual with guages. It is super clean, no issues. |
11-28-2011, 08:02 PM | #21 |
It is currently an Auto but I'm collecting parts to convert it to manual. Going to try to find a little more info.
11-28-2011, 08:05 PM | #22 |
Sounds good
11-28-2011, 08:06 PM | #23 |
What else do you need for the conversion? I may have it. I think i have a pedal assembly. I'll have to look
11-28-2011, 09:43 PM | #24 | |
11-28-2011, 10:03 PM | #25 |
ok
