09-27-2011, 10:28 AM | #1 |
Header flange thickness
It has been suggested to me that I try to find headers with 1/2 inch flanges. I've looked everywhere and they don't seem to be very prevalent. I'm looking to heat wrap a natural finish set of headers, and don't want to weld them up myself, I'm a little green for that level of build. I was hoping that i could keep the cost under $500 I'm not sure if 3/8 is the new standard and I have outdated information, or if I'm just looking in the wrong places. Thanks guys!
Posted via Mobile Device |
09-27-2011, 12:36 PM | #2 |
Restoration Virgin!
Re: Header flange thickness
pending on what engine you are running, I think member Hart_Rod has a custom made set that are very nice....check the parts section...
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-27-2011, 01:18 PM | #3 |
Quit if it's not FUN!!!
Truthfully, I don't think I've ever seen any commercially made headers with 1/2" flanges. About the thickest flange out there are 3/8". Sanderson has 3/8" flanges. Some others do also.
. Another suggestion, if you want heavy flanges, you might consider these: . http://www.speedwaymotors.com/Tru-Ra...olds,3823.html |
09-27-2011, 04:23 PM | #4 |
I to have never seen commercially available headers with 1/2 inch flanges. As far as header wrap, think you should research that a little. They will be dust in about a year. Most header manufacturers void the warranty of wrapped headers.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-27-2011, 05:39 PM | #5 |
So,, what else you got???
5/16 is common, 3/8 premium. Have never seen (not saying they don't make) any commercially available headers with 1/2 inch flanges.
09-27-2011, 05:42 PM | #6 |
bbadfred
I have never heard of a 1/2" flange. 3/8" will be fine, Thorleys have a 3/8 flange and build a nice header.
09-27-2011, 05:52 PM | #7 | |
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-28-2011, 02:08 PM | #8 |
Thanks, this helps a lot. I think it should be easy to find some nice 3/8" flange headers for less than an arm and a leg.
