09-27-2011, 04:53 PM | #1 |
Made a dumb mistake today
I had been looking for another rear end for my truck to convert it from 6 to 5 lug. I already have some rims that I want to use so I started measuring how I wanted the wheels and tires to sit in the fenderwells. I found a guy selling a late model z28 rear end with posi and disc brakes that just happened to be the width I was looking for. I got the rear end home and started to stick my rims on it and they dont fit. I didnt think to check the bolt pattern. I just assumed that chevy 5 lug were all the same. My rims are 5x4.75 and these are 5x4.5. UGH!!!
09-27-2011, 04:58 PM | #2 |
~Rest In Peace~
Re: Made a dumb mistake today
wheels spacers
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-27-2011, 05:11 PM | #3 |
actually your wheels should be 5x5 and the rear end should be 5x4.75
but either way, adapters or getting the axles and rotors redrilled to the pattern you need will work |
09-27-2011, 05:17 PM | #4 |
The wheels are 5x4.75 and the new rear end is 5x4.5. I cant do adapters because they will widen the rear end too much. I think I am going to just have the axles redrilled.
09-27-2011, 05:39 PM | #5 |
Cool Truck
All older Chevy trucks are 5x5. Most GM cars have the 5x4.75, except I know the 91 and newer Caprices and Impalas are 5x5 also.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
09-27-2011, 05:40 PM | #6 |
Just buy new rotors.
I'm not as good as I once was, But I'm as good once as I ever was. |
09-27-2011, 06:06 PM | #7 |
I agree with the others, truck 5 lug wheels are 5x5, Z28 rear ends are 5x4.75.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-27-2011, 06:40 PM | #8 |
here you go.... since a lot of people dont know how to measure bolt patterns properly here is a pic of how to do it
09-27-2011, 07:05 PM | #9 |
That makes sense. Either way I still have to redrill the axles or change out the axles.
09-27-2011, 08:28 PM | #10 |
6>8 Plugless........
5x4.5 is ford and mopar usually. I agree, redrill and save the purchase.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-27-2011, 08:55 PM | #11 |
The Older Generation
To be safe take a wheel with you when you take the axles to be drilled and let them measure it... LockDoc
09-27-2011, 08:59 PM | #12 |
Man of Mini-Talents
Or sell the wheels and get the ones that will fit.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
09-28-2011, 12:54 AM | #13 |
Scrapper 1
we have all learned that one Car's different But Vans trucks suburbans panels and i've even seen some caddy's use the big bolt pattern
09-28-2011, 01:34 AM | #14 |
Fabricate till you "puke"
2nd all of that...redrill. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-28-2011, 07:25 AM | #15 |
Just a car guy
Not to mention that z28 rear end is a 7.5" 10 bolt. These are very week rears and I would not trucst one in a truck, if you plan to do more than just cruise.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
09-28-2011, 07:37 AM | #16 |
Actually Caprices etc. bounced around on size from '71 up, some years had both sizes. I have had a '72 Grandville, '77 Bonneville, and '96 Caprice with the 5x5 and I had an '86 and an '88 Caprice with the 5x4.75. In the words of Shawn Spencer from the TV show Psych "I've seen it both ways".
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-28-2011, 07:48 AM | #17 | |
MadMan
just make sure you get the reach nuts to go with it and you wont have a problem. "IF" you have enough room at the fender...you might have to roll the fenders
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build |
09-28-2011, 11:21 AM | #18 |
Sheetmetal Psycho
I've been measuring the 5 lugs wrong! I always take a rim though. I've screwed up enough times with centers being too small or the pattern being smaller or bigger that I always take a rim.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
