Old 09-27-2011, 06:04 PM   #1
grs
Ball joints bad????
If the part of the ball joint that goes in the spindle is loose would you say that the ball joint is bad.
grs is offline   Reply With Quote
Old 09-27-2011, 06:24 PM   #2
SCOTI
SCOTI's Avatar
Re: Ball joints bad????
Definitely. They should actually require force to shift the joint around within the socket.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-27-2011, 09:56 PM   #3
grs
Well I guess I will have the lower replaced. I guess the top are bad too. Thanks
