Old 09-27-2011, 09:09 PM   #1
El Campo
El Campo's Avatar
Question on radiator catch can
Thinking of building myself a radiator catch can and was wondering does it need to have a cap or can it just have the entrance fitting from when it overflows out of radiator? Also does it need to seal so that it will pull coolant back into radiator or do they not do this? Thanks for helping
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-28-2011, 12:08 AM   #2
LowGT
LowGT's Avatar
Re: Question on radiator catch can
As long as the tube goes all the way to the bottom of the catch can, it will draw up any liquid that's in the catch can. No seal is needed.
I use a Jack Daniels bottle.
65 SWB BBW - 283, TH400
LowGT is offline   Reply With Quote
Old 09-28-2011, 12:11 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i got one from summit racing plastic bottle with mount bracket
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-28-2011, 04:55 AM   #4
cdowns
cdowns's Avatar
yes you need the proper type of radiator cap for a coolant recovery system to work properly and using glass container is a pretty foolish thing to use for an overflow catck can
Old 09-28-2011, 05:57 PM   #5
LowGT
LowGT's Avatar
I think driving a 43 year old truck with manual 4 wheel drum brakes, a gas tank sitting behind your back, and it's best safety device being lap belts while in modern vehicle traffic a pretty foolish thing to do too.... but I do that also.
Old 09-28-2011, 08:43 PM   #6
camrycurt
camrycurt's Avatar
LOL
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 09-28-2011, 09:00 PM   #7
El Campo
El Campo's Avatar
Is it necessary to have it function as a coolant recovery system? Or if I just have it as a occasional overflow and so that I can go on the track is that enough? I was thinking of welding some caps on a piece of exhaust pipe, coating it with some Kreem that I have laying around and powdercoating the outside of it and then putting an AN fitting in the top of it that goes to nipple on radiator neck.
LowGT that is a sweet looking LWB, if it had been me I would have done it with Maker's bottle instead I think :-P
Hook em Horns!!!
Old 09-28-2011, 09:40 PM   #8
Rochlow
I had a buddy that had a toyota tercel in his back yard that he was using for parts. Asked if he was using the overflow tank from it. Got it for free, bent the mounting bracket from the toyota and used an existing hole on the fender to mount it to, ran the hose from the tank to the radiator and done.. 30 minutes.. Took longer to drive to his house to get it.
Rochlow is offline   Reply With Quote
Old 09-28-2011, 10:20 PM   #9
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by El Campo View Post
...snip...I was thinking of welding some caps on a piece of exhaust pipe, coating it with some Kreem that I have laying around and powdercoating
the outside of it and then putting an AN fitting in the top of it that goes to nipple on radiator neck.......
It's always nice to make something yourself. But I bought this one off of E-Slay for about $30 and no shipping.
Using up a good bottle of Kreem and then powder coating has to cost more than that.....no?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-28-2011, 11:21 PM   #10
hemihead
hemihead's Avatar
Had on of those and it didn't work, had to go with a model that would allow coolant to pass in both directions too and from the rad.
Without the valve on the bottom open all the time the tank quick pressurizes to the same pressure as the rad...which means nothing is going in.
Find one with a cap and over flow and return connections.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 09-29-2011, 01:48 AM   #11
magwakeenercew2jh
Ahhh. Thanks. It seems that the top valve is not a press fit...it swivels. So, I figured that there was clearance at the connection for de-pressurization so that the liquid that had overflowed from the rad into the canister would be picked up (when it cooled) at the bottom of the canister thru the tube and sent back to the rad.
If you had an EXACT ONE like this that didn't work, I would be really pleased to find out before I put it to the test.
I appreciate the info. And I'd REALLY APPRECIATE a follow-up so it doesn't get messy in there.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-29-2011, 02:56 AM   #12
fastwillie 696969
~Rest In Peace~
where is your hamster ?
Old 09-29-2011, 05:51 AM   #13
LONGHAIR
You do need a catch can to run at a legitimate race track, but I would check with them about using glass?
Bach in the day there were several cars that had glass bottles, Ford even used plastic bags at one time, but I don't know if those meet race track standards.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-29-2011, 11:33 AM   #14
magwakeenercew2jh
I'm a little thick this morning...only one cup of coffee so far.
You see a nest somewhere? Maybe a man-made nest?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-29-2011, 12:15 PM   #15
Tmwoodall
I think he is referring to your engine...
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 09-29-2011, 12:21 PM   #16
magwakeenercew2jh
Or LACK thereof!
Hahahahaha!!!!
Got it. Thanks!
And now I'm on my second cup of coffee.
Not to be a thread hijacker, but last weekend I DID get the front clip (mostly) on.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-30-2011, 07:35 PM   #17
mightyatom
mightyatom's Avatar
I converted my windscreen washer bottle to radiator overflow, as it was located in the right place and the windscreen washer pump does not work well anyways, so it was just sitting there taking up space. I plan to add a new washer bottle on the other side and get an after market pump so at least it is usable.
Jay
Jay
{ 1972 Chevrolet C-10 Fleetside, 350 V8, 5.7L. }
mightyatom is offline   Reply With Quote
Old 10-01-2011, 03:16 PM   #18
El Campo
El Campo's Avatar
On EBay I see that there is a stainless steel polished 18 oz can for 25 bucks. 10 dollars shipping sucks but that's pretty hard to beat plus its SS. I think I will just go that route.
Hook em Horns!!!
