Brake hoses
I am about so swap some 73-87 spindles rotors and brakes on my 67 swb. I am want to leave it manual disc for now plan on getting and under dash master later but for now what hoses or adapter will i need to mate the calipers to my current factory setup ?
Re: Brake hoses
you can get the proper hoses and banjo bolts for your calipers at speedway motors
Re: Brake hoses
Thanks ,i looked at the site in the brake section but i really don'y know exactly what i am looking for. Any help would be great.
Re: Brake hoses
I have done this swap a couple times , used a 80's impala brake hose with 79-87 (metric hose hole) caliper , raybestos number bh36846 , just check your length at lock / up and down to make sure there is no pull on the hose
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Brake hoses
ECE sells a conversion hose.
Check out www.earlyclassic.com
Re: Brake hoses
