09-28-2011, 12:38 AM | #1 |
15x8 rally's
Looking into some 15x8 rally rims, what would the best tire size to go with them rims? Any suggestions??
09-28-2011, 09:12 AM | #2 |
Restoration Virgin!
Re: 15x8 rally's
are you stock height or lowered?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-28-2011, 09:14 AM | #3 |
Roadtrip!
Re: 15x8 rally's
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-28-2011, 09:34 AM | #4 |
Registered Cruiser
Re: 15x8 rally's
for your truck 255/70/15
I intend to live forever. So far, so good. |
09-28-2011, 10:12 AM | #5 |
Re: 15x8 rally's
My truck is at stock heigth right now should be lowering in the future, and its 2wd...I am wanting street tires..no a/t or anything..more rubber on the road.
09-28-2011, 10:21 AM | #6 |
Re: 15x8 rally's
275-60-15
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-28-2011, 11:44 AM | #7 |
Re: 15x8 rally's
Should i stagger with some smaller in the front..or stick with that all around?
09-28-2011, 12:10 PM | #8 |
Re: 15x8 rally's
for stock ride height (now) or if you know you want same size wheel/tire all the way around, recommend 255-70-15 all the way around - these are tall tires and fill wheelwells nicely.
if you know you're gonna lower it, then I'd stagger and go with 275-60-15 (rear) (i.e. wider, but still tall enough) and 235-70-15 (front) i.e. narrower and slightly shorter (clearance if you need it when lowered) although I'm pretty sure someone could confirm on here whether a 255-70-15 would have interference problems on a lowered truck. Avoid narrow 60's (too short) and 50's period. (i.e. 275-60-15 is a tall tire, so good to go - but DON'T run something like a 235-60...) |
09-28-2011, 12:16 PM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 15x8 rally's
I agree with Jock-o. although mine is a 65, I have BFG Radial T/A 275/60/15 on Ralleys in the rear and 255/60/15 on front, but I will change front to 235/70/15 so the tires are the same height and fill everything out nicely.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-28-2011, 12:55 PM | #10 |
Moderator
Re: 15x8 rally's
275 60 15's on 15 x 8 rallies in the back.
215 70 15's on 15 x 7 rallies in the front. This combo gives a nice rubber rake to a lowered truck, imo. I am running this set up with a 5/7 static drop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-28-2011, 01:02 PM | #11 |
Old Skool Club
Re: 15x8 rally's
I ran 235-70's on my 15x8's, up front. I ran 275-60's on the 15x10's out back.
I currently am running a 16x7 on my GMC and running 255-70's on all four, so I can rotate them. Having different sized tires on the same size wheels, prevents tire rotations. When I replace the tires on my 16's, I'm going with a shorter, i.e., 60-series, tire up front. Yeah, I know....tire rotations going by the wayside. However, the visual aesthetics are an issue with me.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-28-2011, 01:35 PM | #12 |
Re: 15x8 rally's
This is the set up I have ready to go on my truck right now
245/60/15's up front and 275/60/15's in the rear 15x6 up front and 15x8 in the rear.. I will post picts once I am done with it. This is just to change the look from weekend to weekend.
09-28-2011, 03:13 PM | #13 |
Re: 15x8 rally's
so they are taller, but are they decentley wide..right now i have tall ones and they seem to just sit in to much under the fender i want some that will fill them out a lil more outward
