Old 09-28-2011, 09:50 PM   #1
djulbert
Rear End Swap Questions
I have an 86 K10. Broke a tooth off the pinion gear in my 10 bolt. I can't find a axle with same gear ratio as my front and 6 lug locally. I have found a lot of 5 lugs. Question is, if I buy a 5 lug 10 bolt can I change it over to 6 lug using my parts off my rear end? If it is possible, do I have to set up the rear end to do it? I am not comfortable setting up the backlash and all it takes to assemble the differential. Thanks in advance
djulbert is offline   Reply With Quote
Old 09-29-2011, 04:44 PM   #2
chevy355
Cool Re: Rear End Swap Questions
you should be able to take the 6 bolt axles out and put them in the other axle housing. so just swap axle shafts
chevy355 is offline   Reply With Quote
