New vintage 10,000 tach install
so I bought a new vintage 1969 series tachometer to in stall in the dash. no real problems just cut some holes and stick it in... only other thing i did was cut the studs off the back of the tach so the printed circuit would fit. here are a few pics
before ![]() after ![]() ![]() ![]()
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
Re: New vintage 10,000 tach install
Old member
Nice deal,
Where did you get the Tach? What kind of wiring did it take? ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I got the tach from summit, it was 150 bucks after shipping and there wasnt really much wiring. ground, light, hot to the switch, hot all the time and tach signal (mine came from a msd box)
Just a car guy
Looks good. Thinking about going with that series for mine.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
yea I really like it and it looks stock. only problem I have now is that my other guages arent nearly as bright. I may see if I can find sime led bulbs
any one put leds in there dash before?
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
thank you sir
looks close to factory and is probably a lot more accurate.
Doug Looking for a 67-72 short bed driver..... |
