Old 09-29-2011, 10:25 AM   #1
EMPIRE63NH
EMPIRE63NH's Avatar
63 standard heater
Good morning I'm new to the forum, looking for some info I have a 63 short bed fleet side BBW. The heater controls were cut off at the face plate and I need to replace them, the panel has 4 openings but only 2 controls one is blower speed the other is floor and defrost. is there a temp control or just two working levers on the standard heater Thanks ( great forum)
EMPIRE63NH is offline   Reply With Quote
Old 09-29-2011, 10:41 AM   #2
brawley
Easy Does It
brawley's Avatar
Re: 63 standard heater
welcome to the forum, you can get parts from places like classicparts.com or LMC - has good picture diagrams of parts also. yes there is no temp. control on the basic heaters just blower speed and floor or defrost adjustment, you will have to use the floor and window vents for temp. control
brawley is offline   Reply With Quote
Old 09-29-2011, 10:46 AM   #3
awbrown
Make sure you lube and work the cables before replacing the knobs.. I did mine a few monthes ago and maybe should have gotten the cables .....
awbrown is offline   Reply With Quote
Old 09-29-2011, 11:15 AM   #4
EMPIRE63NH
EMPIRE63NH's Avatar
Thanks for the replies I figured that's how the system worked, somebody snipped the tips off of the control arms so I can't put on new knobs will have to get new control arms and knobs ( can't figure out why they would cut those?)
Old 09-29-2011, 03:26 PM   #5
Scot_Douglas
Scot_Douglas's Avatar
I thought there was temp control on the basic heaters - and the difference was the outside air blend door and set of levers vs. one cable you pull to adjust the temp and twist to run the fan... (?)
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 09-29-2011, 04:26 PM   #6
EMPIRE63NH
EMPIRE63NH's Avatar
Scot, I don't have a pull knob or twist control just 2 levers one turns fan speed- low-med -high and the other is defrost or floor,it does not appear i am missing any other parts thanks
Old 09-29-2011, 05:23 PM   #7
Bears63
...just another truck junkie..
Bears63's Avatar
I guarantee the tips were not "snipped", they broke off. It's extremely common. The cables bind up and the extra pressure exerted on the ends of the levers via the knobs snaps the end of the levers off.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 09-29-2011, 08:41 PM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
every set i've seen have been broken off,except maybe the fan switch (its not cable operated).i think the cables cease up and the aggrevated owner just loses it LOL
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
