09-29-2011, 11:30 AM | #1 |
Engine swaps youve thought about?
Just putting this out there to see what engine swap ideas everyone has thought about or has done on our trucks?
Mine is a l67 supercharged 3.8 from a monte carlo/grand prix etc... 240hp or 300 with a pulley,intercooler,and headers. I know i will hear crap about this swap thought but i think this would be a reliable fun cruising engine. |
09-29-2011, 11:44 AM | #2 |
Re: Engine swaps youve thought about?
I would like to do a 4BT swap at some point (last thing if I run out of other things to do). A Duramax would also be cool, but I think the 4BT would be a ton easier to do.
If I stay fossil fuel, I have thought about either a supercharger or twin turbos. But my project is so far from an engine swap at this point, it's just a pipe dream. I love the idea of a supercharged 3.8, post up some pics!
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
09-29-2011, 11:55 AM | #3 |
Mine is also at the far away point but thoughts and ideas
09-29-2011, 11:56 AM | #4 |
Maybe even a grand national swap if they were more readily available
09-29-2011, 11:59 AM | #5 |
My brother was also thinking of doing a cummins swap,said you only really need like three wires or something to actually use it.
09-29-2011, 12:36 PM | #6 |
Here's one I'm thinkin about....
Cause it's pi$$in me off............and it still aint finished.... But I'm gettin there. I just had to pipe up on that one..... I'll take it over to my thread. BTW...the only addition to this 351E that I've pondered is adding a Turbo. IMO....the BB V-6's were made for boosting. Might be the best thing a feller could do with one.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
09-29-2011, 12:42 PM | #7 |
1965 Chevy C10, 2005 4.8L/4l60
I like your little lifting buddy there Les!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-29-2011, 12:49 PM | #8 |
Thats a pretty good idea also
09-29-2011, 12:56 PM | #9 |
I really want to put a Vortec 4200 Inline 6 from a Trailblazer/Envoy in my '66 C10. I'd strip all of the factory EFI off and convert it to sidedraft Dellorto carbs (3 two barrels) on individual runner intake manifolds. I'd use a 5 speed from a Colorado/Canyon. I think that Web Cam will regrind the factory cams (nobody makes cam blanks for these engines) and I've found a company that makes rear sump oil pans to clear the crossmember and flywheels to convert it to a manual trans. These things are 290hp stock and it shouldn't be to hard to get it up to ~375hp with the carbs, cams, header/exhaust, and some porting. There's not much aftermarket support for these engines yet but I think there's alot of potential in them.
Besides, how wrong would it be for a 1960's American truck to sound like this!?
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 09-29-2011 at 12:56 PM. Reason: Spelling |
09-29-2011, 12:57 PM | #10 |
Thx, Clyde....
That thing kicks a$$.
09-29-2011, 01:37 PM | #11 |
Senior Enthusiast
I’m pretty conventional in my thinking. I would have preferred a Pontiac 389/4 speed in my truck. I always liked the engine and it would have been way more cool than a small block Chevy. But the reality is the SBC is cheaper than anything else so I’m pretty much stuck with that from here on out.
Have to admit though, having a truck that sounds (and accelerates) like the 240Z in the video would certainly be cool. |
09-29-2011, 01:52 PM | #12 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
09-29-2011, 05:52 PM | #13 |
check out the inliners website there are a couple df guys running those sixes with turbo's
09-29-2011, 05:53 PM | #14 | |
Just here to tinker
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
09-29-2011, 06:39 PM | #15 | |
s10 2.2l 4 cylinder in my 65.
keep the efi, you will quintiple the cost of your engine just buy going to a sidedraft carb setup and it will only perform at WOT. EFI though gives you tuning for whatever, not just those 2 days out of a thousand that you are on a track. Not to mention I had twin sidedrafts on my BMW 2002 and what a ***** to sync and tune for changes in weather... not knocking your choices, just saying
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
09-29-2011, 06:59 PM | #16 |
I myself have considered the L67 supercharged 3800 V6 swap, I even went as far as buying an engine and wiring harness, biggest problem I can see is the throttle body would be pointing directly at the firewall and too close to put a U bend on it so you would either have to cut a hole in the fire wall and have the air cleaner inside the truck or get a supercharger off an Australian Holden car, they are set up for rear wheel drive already.
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
09-29-2011, 09:00 PM | #17 | |
09-29-2011, 09:04 PM | #18 |
Call me old school, I'd like to do a 401 or 425 Nailhead Buick w/SP400 trans. But not in the truck I have now.
Duramax would be bad *ss in a 4x4 though....
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
09-29-2011, 09:43 PM | #19 | |
apples to oranges my friend. you are using a well developed carb system with YEARS of tuning behind it on an air cooled motor that is very likely less than 80hp and comparing that to having a custom manifold and linkage made and expecting to better the factory hp. how will you get spark? the 6 cyl is crank triggered with coil packs and doesnt have a dizzy hole. add a thousand, maybe more for a crank ring and hall switch and standalone box. GM OBDII are just about open source nowadays, you can have the ecm reflashed not to need the trans (except the speed input, but you will have that with a colorado trans anyway) get rid of the key stuff, get rid of just about anything you dont want really. Toyota guys are using the 4 5 and 6 modular gm inlines with trans adapters and the pcm work is 2-500, about 1/5th of what you will pay for your custom carb setup with three carbs. the engine already has everything it needs to run, why would you get rid of it? might as well keep the inline 235 and run duals or triples on it.
09-29-2011, 10:26 PM | #20 |
I have a 348 tri-power sitting on a stand in the shop that will likely find it's way into my '64 shortfleet 4X4. I DO like the nailhead idea though, but I don't have one of those.
09-29-2011, 10:40 PM | #21 |
500 CI Caddy. 426 Chrysler Hemi. Cummins Diesel. All nice thoughts but I am putting a 454 in it because it was free.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-29-2011, 11:08 PM | #22 | |
Posted via Mobile Device Posted via Mobile Device
09-30-2011, 05:35 AM | #23 |
I have an '03 Envoy with the 4.2L and it runs good and with the EFI is pretty good. I could see it working in one of our trucks just fine. Not fast by any means but quite acceptable for a light duty pickup.
Me: I have a fresh '64 409 that I think would be really cool in my '65 |
09-30-2011, 06:17 AM | #24 |
I couldn't afford the gas.... but, a big block cadillac 500 motor.
-W |
09-30-2011, 06:51 AM | #25 |
"Where were you in '62?"
The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
http://67-72chevytrucks.com/vboard/s....php?p=4887434 Kirby Race Truck - One Bad A 1950 Chevy truck with a 292 inline six cylinder! http://67-72chevytrucks.com/vboard/s...d.php?t=450632 Mighty6 - A 1936 1/2 Chevy Pickup with 857rwhp 292 Chevy I6 http://67-72chevytrucks.com/vboard/s...d.php?t=473484 This '62 Chevy has the right look with its satin black paint scheme with yellow accents, and it's definitely unique, thanks to a Cummins diesel powerplant. Tom Sendelbeck owns the low-down stepside.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
