09-29-2011, 11:41 AM | #1 |
Dropmember rack and pinion Question
How much thread do you cut off the rack ends?
09-29-2011, 12:13 PM | #2 |
67-72 parts collector,…
Re: Dropmember rack and pinion Question
From Nates website:
http://www.porterbuiltfabrication.co...ructions/page2 The tie-rod assembly will mount to the top side of the steering arm. It may be necessary to trim the ends of the rack and pinion tie-rod in order to achieve proper toe adjustment. We have had to trim as much as 1.5” from each end. Leave the jam nut installed while you cut the tie-rod, and use it as a thread chaser once the end has been cut-off
09-29-2011, 02:51 PM | #3 |
I dont know why I couldnt find that right now. Thanks. I was going to cut like 3 inches off
09-29-2011, 07:10 PM | #4 |
I cut a little over 1/2" off mine and it looks lined up pretty good.... MAKE SURE you leave that nut on there before you cut it... that way after you cut you can unscrew the nut to line the threads up.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
