Old 09-29-2011, 12:30 PM   #1
bulldoze76
problems with my single wire alternator conversion.
Hey guys I have a 65 c10 swb fleet side w a 350/350 tranny. I had read about the single wire conversion for the truck. I got a 85 trans am alternator (i think a 95 amp?) and installed it per the directions. Now the problem I have is the tail lights and turn signals are not working like before, the aftermarket fuel pump (did the tank to rear bed conversion) is now putting out 9-10 lbs of fuel (used to do 5) and when I take the key out it will still run for awhile (30- 50 seconds) I think until the fuel pressure dies down.
Is it maybe the relay on the grill that it is plugged into? Is it just cranking out way to much power for the truck?
The PO had put in a painless wiring system, but only hooked up the essentials and I went through the whole truck re hooked up everything, redid all the grounds, and all the lights were working and the fuel pump and all worked well.
I also dont think the battery is getting charged because it is always dead. I checked the amps going to the battery it is 14
any advice would be great.
bulldoze76 is offline   Reply With Quote
Old 09-29-2011, 01:22 PM   #2
A.T. RockDriller
A.T. RockDriller's Avatar
Re: problems with my single wire alternator conversion.
A few things....
It sounds like you bumped the wire harness plug on the firewall that feeds the rear lights.....wiggle that thing while someone looks.
Also sounds like you have battery power to the distributor....should be ignition power.....that way when you turn off the key.....she dies.
I have to reread yer message.....maybe there is more.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 09-29-2011, 01:29 PM   #3
A.T. RockDriller
OK.....if you fix your power supply to your distributer....that'll maybe fix your voltage drain.....dead batt.
14 volts is correct from the alt.
The fuel pump might be liking the good power it's getting and may be performing like it should. 10 psi should be ok for most carbs.
That might be it....try that stuff and let us know.
Les Hunter
Old 09-29-2011, 04:05 PM   #4
bulldoze76
i had installed a super coil and sure enough it was hooked up on the acc spot. tach not working now but the baby had woke up and had to call it quits....thanks again
Old 09-29-2011, 04:21 PM   #5
forestb
forestb's Avatar
Is it an internal regulated alternator? If it is you will need the adapter to bypass the external voltage regulator that should have come with the truck. I Bought one from American auto wire. It is just a thought.
forestb is offline   Reply With Quote
