Old 09-29-2011, 01:48 PM   #1
Born Lucky
unfortunate incidents-sparks and idea!
I decided to take a day off from work and work on my truck. My wife gives me an option, go thift store shopping and the Halloween store for our boy.
Great, mother in law and us just into her Kia Sorrente and drive off.
As we start pulling into the parking lot we hear thump thump noises. We discover a flat, and the BAD GUY is a side cutter. I could not believe! The head of a side cutter, wire cutter or what ever you want to call them!
So, here I am day off and having to change a flat tire. I remove the tools from tray, hook up the jack, and go looking for the spare. I find it tucked under the rear, but could not release the tire. At this point I go for the owner's manual and find the info. The application calls for using the lug wrench and turning a big nut ( same size as lugs) to lower the tire. Wow! I think this set up would be COOL in my 64.
I take the system operates via pully's, turn the nut one way to lower and the other way to raise the wheel,lowering and raising a cable.
What do you think?
Born Lucky is offline   Reply With Quote
Old 09-29-2011, 02:32 PM   #2
Scot_Douglas
Scot_Douglas's Avatar
Re: unfortunate incidents-sparks and idea!
Do it!
Way back in the early 90's I helped build a hybrid electric car; we loaded teh trunk with LPG bottles and bought one of the gizmos you mention to mount the spare underneath the car (Neon) where the gas tank used to be. I think it was from a F150 (?).
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 09-29-2011, 02:48 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I used one off a Nissan truck, on my camping trailer, to get the spare up under the tongue box.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-29-2011, 03:20 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
I had an '88 S-10 years ago, and it had a similar set-up. It had a receptacle to the left side of the license plate that you put the jack handle in. Turn it to the left, the wheel/tire assembly lowered down. There are tons of S-10s in the wrecking yards, so maybe you can find one cheap.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-29-2011, 03:44 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
our 2005 silverado has this setup... neat idea, but way over engineered.....
Old 09-29-2011, 04:06 PM   #6
Surfdaddy
Surfdaddy's Avatar
I had the sme set up on my 69 F250 with a camper on it. That was the only way to get the tire out.
I put the spare in my 61 with the clamping bar that came stock and what a pain to get back in. Stock spilt rim and radial tire was heavy but I could't seem to get enough leverage or stroke to get it together. I finally used a jack to get the thing compressed enough to get it together. I thought of the pully / winch system in the other truck while I was going through that.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 09-29-2011, 04:14 PM   #7
gearheads78
gearheads78's Avatar
I have one off a Chevy truck welded under the front of my trailer.
gearheads78 is offline   Reply With Quote
Old 09-29-2011, 04:15 PM   #8
Born Lucky
But way COOL!!!
So from what I am reading this set up can be found at my local Pick and Pull.
Old 09-29-2011, 08:24 PM   #9
rideblue00
rideblue00's Avatar
I have a 98 K1500 with that setup. I thought that would be great idea as well.
rideblue00 is offline   Reply With Quote
Old 09-29-2011, 08:28 PM   #10
BMERDOC
BMERDOC's Avatar
My '04 Tahoe had it. Junk yards should be stacked waiste deep with them.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-29-2011, 08:53 PM   #11
Str8axle
Str8axle's Avatar
Square body S10 would be the best place to look. Finding one that still works and doesn't have the cable end rotted off may be a challenge.
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 09-29-2011, 09:21 PM   #12
creep
Registered Loser
creep's Avatar
I think most modern trucks have a similar setup.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 09-30-2011, 10:53 AM   #13
Dustin07
Stirrer of the Pot
yah I was going to say it sounds just like my old '99 silverado.
I had to get rid of the spare when I bagged the truck lol
Dustin07 is offline   Reply With Quote
Old 10-01-2011, 02:12 AM   #14
Dion Hildebrandt
a few years ago I built a 1978 lowrider c-10, and put a space saver from an astro van (dual bolt pattern rim) under the bed with a spare tire hoist out of a late 90's chrysler minivan. The setup is compact and really easy to install with a little fabrication the 'bolt head' was in the box floor and worked awesome. When I say lowrider, it was a static drop and a pop can rolled under the truck would not make it past the rocker panel.
Dion Hildebrandt is offline   Reply With Quote
Old 10-02-2011, 05:10 AM   #15
Ornery37
my 97 dodge pu had it untill the cable broke, the tire bounced the truck, then went rolling down the road...luckly no one was around.
1964 long fleet bed large rear window (project)(sold)
1965 chevy short fleet large rear window bagged (project)(thinking crew cab)
1965 chevy short fleet (driver/worktruck)
1937 chevy fenderless pu (use to be daily driver)
1983 MB turbo diesel (daily)
Ornery37 is offline   Reply With Quote
Old 10-04-2011, 04:25 PM   #16
Woogeroo
'85 and 2003 s10 are like that... mid 90's full size as well... I bought one from a junkyard... was pondering using it under old '65 c10 before I found the original parts.. may still use it, dunno yet.
As others mentioned, should be easy to find... a lot of the GM mini van's from 90's to 2000's used them as well.
-W
Woogeroo is offline   Reply With Quote
Old 10-04-2011, 05:22 PM   #17
aaronh33
i think you can also get them from places like LMC truck parts and JC Whitney. the one i had on my 2003 s10 broke some how and was looking for a place to get a new one. for some reason $30 sticks in my head for the price but dont quote me on that.
aaronh33 is offline   Reply With Quote
