Jeep 5 on 5 wheel ?
Does anyone know if jeep wheels from a newer Cherokee or wrangler with the 5 on 5 bolt pattern will fit? I know it's the same bolt pattern as a 2wd gm but what about the hub bore. Thinking on putting srt 20x9 +35 offset and 20x10 +50 offset repo ram viper wheels that they sell on eBay on my stepside.
[ Last edited by lifted k10; 09-29-2011 at 03:23 PM. Reason: Forgot to add some info |
Re: Jeep 5 on 5 wheel ?
Newer wheels use more backspacing than older ones. If they do bolt on, they will be tucked into the fenders quite a bit. Just to give you an idea, a stock 8" wide rim has a backspacing of 4". Not sure what your new wheels are but you can compare it to that baseline.
1977 GMC Sierra Grande |
So basically with the correct spacers I could probably get them flush with the fenders
Posted via Mobile Device |
Jeep wheels have smaller hub bores, the wheels will not bolt on unless you machine your hubs or wheels. If you have spacers/adapters made you can make sure they are hub and wheel centric. www.motorsport-tech.com
